Old 01-02-2006, 04:03 PM   #1
Default toe in, toe out ore 0 degres
what are you guys driving indoor i have tryed toe in and toe out so fare i like toe out best but i will try 0 degrees tomorrow what do you guys think
Rasmus TbEvo IV is offline   Reply With Quote
Old 01-02-2006, 05:44 PM   #2
front or rear?
cvt01 is offline   Reply With Quote
Old 01-02-2006, 05:52 PM   #3
Registered User
losirunner's Avatar
Send a message via AIM to losirunner Send a message via MSN to losirunner Send a message via Yahoo to losirunner
rear needs -1 degree camber(toe in) and i generally run 0 or -1 degrees up front
losirunner is offline   Reply With Quote
Old 01-02-2006, 05:54 PM   #4
nrtv20's Avatar
0 degrees... if you want more turn in toe out.
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 01-02-2006, 06:20 PM   #5
Burlap's Avatar
Send a message via MSN to Burlap
I think you should be posting this in the EVO IV thread rather than making a separate thread.
Burlap is offline   Reply With Quote
Old 01-02-2006, 06:30 PM   #6
are you saying that toe in and camber are the SAME thing?????
MManson is offline   Reply With Quote
Old 01-02-2006, 06:49 PM   #7
Maybe he's trying to say he uses -1 degree of camber and toe-in in the rear??
But no...Camber and Toe in are different things.
Ben.C is offline   Reply With Quote
Old 01-02-2006, 06:59 PM   #8
heh, i know that, just making sure he does so people dont get confused.
Old 01-02-2006, 09:20 PM   #9
Send a message via AIM to R/C Anonymous
in my experiences every track, car, and driver combination like different settings...i think you should try a few different ones and ind whats most comfortable and consistent to drive and faster speeds
i usually start at 2 toe-in in the rear and 0 toe out in the front for a general starting setup
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 01-03-2006, 10:55 AM   #10
all right thanks guys i just wanted some info becaue normally i dont change the toe in
Old 01-03-2006, 11:23 AM   #11
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Once you figure out how much front toe you want, then you can play with bump steer to make it even more confusing
Old 01-03-2006, 11:50 AM   #12
what is bump steer hehe
