YOKOMO Touring Car BD-8 >
Like Tree125Likes
Old 12-08-2021, 10:11 AM
  #1066
Originally Posted by Ocelot71
Hello,
I just picked up a bd8 that I am going to run in VTA, do either BD9 or BD10 Front arms work on a BD8? I also run a bd10 in 21.5, looking to carry parts that interchange
You will be able to fit BD9 arms after some sanding. Bit as the mounting point for shock is a little bit on different place it will not drive as good. I couldn't make it work. With BD9 front arms the car wasn' reacting to any setup changes. Try front arms from ARC R11. You just need to sand the rear of the arm to fit 3mm spacer in front.
desaix is offline
Old 12-08-2021, 12:12 PM
  #1067
Trader Rating: 15 (100%+)
Thanks for the info, I was able to find four sets of bd8 front arms and bought all four
Ocelot71 is offline
Old 04-29-2023, 02:10 PM
  #1068
Seatown's Avatar
Trader Rating: 16 (100%+)
Default Compatible parts
Hello,
Can someone please point me to the list of BD7 parts that are compatible with the BD8.
Thank you
Seatown is offline
Old 04-29-2023, 09:09 PM
  #1069
EDWARD2003's Avatar
Originally Posted by Seatown
Hello,
Thank you
https://teamyokomo.com
EDWARD2003 is offline
Old 05-10-2023, 07:40 AM
  #1070
Seatown's Avatar
Originally Posted by EDWARD2003
Thank you.
Seatown is offline
