YOKOMO Touring Car BD-8 >
Like Tree125Likes
Old 07-21-2017, 06:37 AM
  #571
Diavel's Avatar
SV Kit comes with aluminum bell cranks as well
Diavel is offline
Old 07-21-2017, 07:36 AM
  #572
Do you have the SV kit. What are the part numbers for the belts. Are they standard to the bd8 or different. Asking as pulleys are bigger
Scott_83 is offline
Old 07-21-2017, 08:56 AM
  #573
They are new belts.
BKUK is offline
Old 07-21-2017, 10:18 PM
  #574
rc_square24's Avatar
Whats a safe way to remove silicone oil from belts due to a leaky diff?
Water and soap? From my experience motor spray will make rubber/silicone swell so I'm avoiding to use that.
Thanks!
rc_square24 is offline
Old 07-22-2017, 04:25 AM
  #575
Airwave's Avatar
water and soap seems to be the safest way.
Airwave is offline
Old 07-24-2017, 02:11 PM
  #576
tkge's Avatar
Trader Rating: 123 (100%+)
Is the 40T stock conversion really worth the money for 17.5 racing? I see lots of setup sheets for in on PetitRc, but didnt really see a lot of feedback on here.
tkge is offline
Old 07-24-2017, 05:49 PM
  #577
I still cannot figure out why the front and rear crossbrace for bulkheads that are extended versions are not included. I don't care what the excuse is. Should be included both front and rear for like $100USD for the conversion instead of $60USD and then maybe like $30USD x 2 for the braces. Hopefully they are only $20USD each, but I doubt it.
190mph is offline
Old 07-24-2017, 07:28 PM
  #578
tkge's Avatar
Yeah I really don't care too much about the cost if the benefit is really worth it.
tkge is offline
Old 07-25-2017, 04:49 AM
  #579
Really poor in my eyes.
I ended up getting them from banzai in Japan a lot cheaper than in UK.
BKUK is offline
Old 07-25-2017, 11:11 AM
  #580
b20btec's Avatar
It's worth it to me but i'm not sure if it's worth it for everyone else. Car is easier to drive now..without that said I have more consistent races.
Plus side I can now use my older diffs and drive train parts as well. I had issues with the 34T diffs in the past and never with 40T, with that said I have more confidence finishing a race.
If you ask me if it's worth it, I say hell yes. If costs isn't a factor try for yourself and post your results.
I commented earlier on the bulkhead shims on how you gotta line it up correctly, that's the most important part of the conversion.
b20btec is offline
Old 07-25-2017, 11:48 AM
  #581
tkge's Avatar
This is the info I was looking for. Thanks!
tkge is offline
Old 07-25-2017, 05:41 PM
  #582
Djchow85's Avatar
In what way was it not easier? Inconsistent, car more floaty and driving lines lacked consistency?
Do the bigger pulleys also provide more forward bite?
Djchow85 is offline
Old 07-25-2017, 07:04 PM
  #583
b20btec's Avatar
Car was very darty and didn't roll as easy. I would have to say no, it wasn't much more noticeable when I ran it on asphalt.
b20btec is offline
Old 07-29-2017, 10:17 AM
  #584
brad996's Avatar
what changes is everyone making to there cars after converting to the 40t kit. I ran mine last weekend and made no changes other than installing the kits and now the car want to oversteer on corner exit. It gets better later in the run. I forgot I did make one change I installed the 1 piece front/rear B mount. This is on gray ozite carpet
brad996 is offline
Old 07-30-2017, 11:10 PM
  #585
Default Rtc in blinky
Hi all. Has anyone tried the rtc in blinky?
Scott_83 is offline
