3Racing Sakura Advance Touring Car >
Like Tree12Likes
Old 11-14-2017, 05:47 PM
  #136
HaulinBass's Avatar
Trader Rating: 14 (100%+)
Hello sorry for my rather basic questions but Ive decided to try onroad this winter. Ive gotten a sakura ultimate 2014, from what I can tell its the model before the advance.
would I be able to use setups posted for the advance as a base? or is the geometry and weigh balance two different? not finding anything for carpet for the ul14.
obviously being new setup wont matter much just like to get pointed in the right direction.
ill be mostly running grey carpet unless I end up trying a wcics race but that is doubtfull
Texas Postman likes this.
HaulinBass is offline
Old 11-14-2017, 08:16 PM
  #137
(0000000000)'s Avatar
It uses big bore shocks, so it's probably similar to the Advanced. Check out setups for the Xi Sport also, as the Sakura cars share a lot of parts.
(0000000000) is offline
Old 12-19-2017, 01:46 AM
  #138
gabc's Avatar
Default MTS T2 vs 3racing Advance
Deciding between the MTS T2 n 3racing Advance. Appreciate honest feedback if you've experience with these 2. Thanks!
Gab
gabc is offline
Old 12-19-2017, 02:08 AM
  #139
Depends where you are getting your spare parts and if anyone else runs the car locally.
I went the Sakura route because parts were available from several online vendors I regularly frequent.
Old 12-19-2017, 03:00 AM
  #140
gabc's Avatar
Good point 10zeros. If parts support being equal, which car will be a better choice?
Gab
gabc is offline
Old 12-19-2017, 09:25 AM
  #141
Either would be fine. The mst appears to be a bit older.
What is your opinion on it all? Where do you race and what classes do you run?
Old 12-19-2017, 08:21 PM
  #142
gabc's Avatar
To me it's all something new so I've no reference point. 😀
This will be me first tc. I run off-road, F1 n M Chassis.
For tc I'll be running both mod n stock, depending which track I'm at for that day.
Gab
gabc is offline
Old 01-09-2018, 01:54 PM
  #143
I purchased this kit from RCMart 3 weeks ago, and my kit came with steel outdrive cups instead of aluminum. Great kit for the price.
DoroSam is offline
Old 01-24-2018, 04:11 PM
  #144
Can some of you guys post pics of this chassis
TeamThibault is offline
Old 01-24-2018, 04:30 PM
  #145
Dobbs's Avatar
Trader Rating: 30 (100%+)
Anyhting in particular you are looking for?
Attached Thumbnails 3Racing Sakura Advance Touring Car-100_4366.jpg   3Racing Sakura Advance Touring Car-100_4367.jpg   3Racing Sakura Advance Touring Car-100_4368.jpg   3Racing Sakura Advance Touring Car-100_4369.jpg   3Racing Sakura Advance Touring Car-100_4370.jpg
Dobbs is offline
Old 01-24-2018, 05:01 PM
  #146
Sway bars
Old 01-27-2018, 04:47 PM
  #147
Bartolo Racing's Avatar
Gab
I carry all parts for the MTS T2
Marcos.J and Texas Postman like this.
Bartolo Racing is offline
Old 02-02-2018, 11:18 PM
  #148
Had a big race this past weekend. The car handled very well. Predictable, aggressive when it needed to be, but never had an issue with traction rolling. Good corner speed, and plenty of acceleration.
I'm going to have to give this setup a go. Still having high traction issues as the night goes on. When you list the downstop as 1mm over ride height, are you 1mm of up travel in the front before the wheels lift, or 6.4? 1 Seems low and 6.4 seems high, however! I haven't tried...
And the sheets don't list, but I assume you are running the stock shim width for the inner tie rod mounts, with the rear outer on the furthest from the rim mounting position (shortest link)? The 2mm noted if for the inner mounts to lower roll center?
ogio855 is offline
Old 02-07-2018, 01:25 PM
  #149
I'll take pics of my car tonight or tomorrow. Yes, I have been running very minimal droop in the front. Car handled well but I did notice that I could use more corner speed. If you notice better results with different droop setting myself, please let me know.
I finally got around to installing my 2.5mm chassis and it felt stiffer, like it had more corner speed now. My brakes were a bit soft, so I think I can enter turns a bit hotter and use more braking - I also switched out my Orca vx3 for a Scorpion ESC when I swapped to the 2.5mm chassis plate.
Old 02-07-2018, 09:17 PM
  #150
Scostin's Avatar
I am being told that the Turnigy TD10 V2 not the original is the same as the Ultimate kit, is that true? Would love one for VTA racing o 2 of them and at their 70 bucks a kit could pick up kits and stock up on spare parts from tq
Scostin is offline
