XRAY X12 2017 1/12 Pan Car >
Like Tree9Likes
    Hide Wikipost
Old 03-17-2017, 02:50 AM   -   Wikipost
R/C Tech ForumsThread Wiki: XRAY X12 2017 1/12 Pan Car
Last edit by: R Dodge
Welcome to the XRAY X12'17 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. Many of us run the X12'17 on high bite carpet and with most US tracks going to the new black CRC carpet, most setups from here out will be developed for those high bite conditions.
Tips & Tricks:
Some racers notice slop developed in the front end over time. One method to reduce/remove this, as pointed out by some of our friends in Europe is to score the inside of the plastic front pivot ball (where the kingpin goes through) with a sharp xacto blade. Usually 4 scores at 12, 3, 6 and 9 will do. Alternative options can be found listed below.
As with any 1/12 pan car, a smooth operating suspension is critical to performance. It is recommended to polish your kingpins & hinge pins using a dremel or a drill and some sort of polish (IE Gravity polish or Mothers Aluminum polish will work). If you find that your suspension has a bind, you may look at using a reamer or drillbit to make sure the holes are clear of any flashing or debris. The only place this may happen is at the upper hingepin, which is 2mm dia.
For stock racing we usually find ourselves looking for a little more steering. One trick that some of the stock drivers have done that seems to help is lowering the graphite plate that the servo & shock mount to. To do this, you will need the 17mm standoffs from VBC and the servo mounts from the 2015 or earlier X12. Be careful that the servo mounts do not sit crooked on the plate when attaching it; a 0.2-0.5mm shim will help ensure it sits perfect on the graphite plate. Part numbers can be found below.
Option Parts to consider:
XRA371220 X12 Foam Bumper
XRA372012 Composite Front Upper Arm Mount Right Graphite
XRA372022 Composite Front Upper Arm Mount Left Graphite
XRA372113 Composite Suspension Arm Front Lower Right Graphite
XRA372123 Composite Suspension Arm Front Lower Left Graphite
XRA372177
Spring 4.75 Coils 3.6x6x0.45mm, C=2.0 - Silver (Soft) (2)
XRA372178
Spring 4.05 Coils 3.6x6x0.45mm, C=2.5 - Black (Soft) (2)
XRA373584 Side Spring C=0.6 - Silver (2)
XRA373586 Side Spring C=1.2 - Black (2)
XRA375010 Graphite Rear Axle Shaft - highly recommended
XRA378094 Shock Spring C=2.1 Black
Lowered Graphite Plate:
B-02-VBC5005
XRA376255-O Alu Servo Mount - Orange (2)
Front end options:
ASC4403 Kingpins, 1:12 Scale
ASC4622 Upper Arm Eyelets
ASC4626 Upper Arm Mounts/Steering Blocks
ASC4627 Front Axles
ASC8417 Pivot Balls
Aluminum Chassis:
Max.FX Aluminum Chassis
McFactory Motorsports
Reflex/RSD
Recent Setups:
Alexander Hagberg - Snowbird Nationals - Mod - High Bite
Craig Xavier - Snowbird Nationals - 17.5 - High Bite
Robbie Dodge - Snowbird Nationals - 17.5 - High Bite
Eric Anderson - ROAR Carpet Nationals - 13.5 High Bite
Print Wikipost
Old 11-09-2016, 08:24 AM
  #121
Regional Moderator
kansasracer's Avatar
New to the xray car. What center springs work with it? Just Xray or do the asscoiated ones work as well?
kansasracer is offline
Old 11-09-2016, 11:17 PM
  #122
Car Breaker's Avatar
AE center shock spring doesn't work. Front spring do, side spring need different spring holder.
Car Breaker is offline
Old 11-12-2016, 12:16 AM
  #123
I look to some setup sheet from the factory drivers
I see there for front spring sm 18 or sm 19
what type and brands its sm 18 front spring
truggy100 is offline
Old 11-12-2016, 01:02 AM
  #124
antlockyer's Avatar
Speedmerchant
antlockyer is offline
Old 12-13-2016, 05:30 PM
  #125
jakeb's Avatar
Hey Everyone,
Was looking at picking up this kit and was talking with a few people at the track and they were saying it's a great kit however the front end develops play.
Is this the case for the 2017 kit or was this from previous kits?
Really interested in this car but don't want to buy a parts depot.
Look forward to your input.
- Jake
jakeb is offline
Old 12-15-2016, 08:32 AM
  #126
Zerodefect's Avatar
Front end has some play. After fixing it, it's not really much more than other cars.
You can shim the upper arm pins and drag a knife inside them to reduce that play.
You can drag a knife in the eyelets and arm to reduce that play. 4 lines only.
You can use a plastic ball to replace the steel ball to reduce play.
You NEED to have a Hudy 3mm reamer to ream out the plastic ball and kingpin when they are installed.
You'll need to polish the kingpins.
I'm not sure that the play has any effect on the cars performance. But the lack of any kind of stiction sure does.
Zerodefect is offline
Old 12-15-2016, 09:00 AM
  #127
Trader Rating: 87 (100%+)
Subscribed
MUDVAYNE is offline
Old 12-16-2016, 04:28 PM
  #128
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
AE springs fit perfectly fine with the stock holders. Just flip the spring around.
andrewdoherty is offline
Old 12-16-2016, 09:21 PM
  #129
jakeb's Avatar
Thanks, Zerodefect.
I've got a well cared for and used 3mm reamer (XB4, XB2, XT2, and T4). It gets a workout a few times a year.
Drag a knife? Like lightly score some lines?
Also since this will be my first time back in 1/12th scale in about 25 years I'll have a few more questions pop up I'm sure.
Does the X12'16 Hiro Seiko screw kit work for the 2017 car?
- jakeb
jakeb is offline
Old 12-17-2016, 02:15 PM
  #130
Customworksking's Avatar
Trader Rating: 74 (100%+)
tag
Customworksking is offline
Old 12-17-2016, 02:18 PM
  #131
best body for 13.5 >>>>Strakka-12 LW ?
Old 12-17-2016, 02:36 PM
  #132
Team EAM
Trader Rating: 79 (100%+)
Originally Posted by jakeb View Post
Thanks, Zerodefect.
- jakeb
yes the 2016 Kit will work witht he 17 car. The ones I have in stock are actually 17 kits. It was just a part number change is all. They all come with a few extra screws in the kits.
EA
EAMotorsports is offline
Old 12-18-2016, 07:53 PM
  #133
Default my lid
simple
Attached Thumbnails XRAY X12 2017 1/12 Pan Car-img_2417.jpg
Old 12-19-2016, 08:38 AM
  #134
Flygio's Avatar
Originally Posted by Customworksking View Post
simple
Seriously?
Flygio is offline
Old 12-19-2016, 12:40 PM
  #135
Zerodefect's Avatar
Thanks, Zerodefect.
- jakeb
When you drag a #11 exacto blade across plastic is scores a line into the plastic, but the plastic on each side of the line raises up. That removes play, and still has very little friction.
Like dragging a stick across sand. It's deeper in the middle, but taller at the sides.
