Old 03-14-2006, 07:05 PM   #31
heavy's Avatar
Trader Rating: 20 (100%+)
The early Yokomo onroad car (YR4 ? ) had a 2 speed option available. It was a very well engineered and light weight piece of equipment taht worked extremely well up to a point. At that time we were using much less capacity batteries (1700mah or maybe 2000 mah) with much less voltage.
If teh 2 speed was adjusted to change at just the right spot when teh battery was fresh then it didn't change at the right spot once the battery started to go down. We messed with it a fair bit and loved it but because of teh rules we couldn't race with it so eventually lost interest - but I'd love to try it again with the batteries we have now.
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 08-02-2006, 07:11 AM   #32
Hayden's Avatar
as was stated before ^^ a gear box for electric is a waste of time for "speed + torque"
Hayden is offline   Reply With Quote
Old 08-02-2006, 08:38 AM   #33
Ennjay's Avatar
I might be wrong, as I've never owned one, but aren't e-maxx's 2 speed? I think alot of guys will make it 1 speed for racing, but I think they are 2 speed when box stock.
Ennjay is offline   Reply With Quote
Old 08-02-2006, 09:12 AM   #34
slightly off topic but has anyone thought that a geared system may be the answer to the overheating issues we are having ie the worlds, if we had gears the motors wouldnt be pulling tall ratios at low speeds ie less heat build up, just a thought?
LEE UK is offline   Reply With Quote
Old 08-02-2006, 10:08 AM   #35
vtl1180ny's Avatar
R/C Tech Charter Subscriber
With brushless and LiPo you may see a return of the 2 speed electric since they can provide the same performance through the entire pack.
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 08-02-2006, 10:18 AM   #36
pheyhoe's Avatar
Yeah brushless would get rid of all that arcing sombody mentioned earlier.
Even though it does not seem to work on paper i would sure like to see a decent system on a car with brushless and LIPO.
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 08-02-2006, 10:40 AM   #37
Suspended
Trader Rating: 14 (100%+)
Infinitely variable split pulley; much better, with no shock to the motor. They are used in machinery; lathes, mills, drill presses. They are very durable, and not extremely complicated.
Phatkat is offline   Reply With Quote
Old 08-03-2006, 03:49 AM   #38
Hayden's Avatar
can you 2 speed 1930 into a modified electric colt
Old 08-03-2006, 07:38 AM   #39
bxpitbull's Avatar
The latest car action has a brushless conversion installed in an LST2. Two speed worked like a charm in both low and high gear settings. Because of the instaneous punch fed by the batteries (they used Li-Po), it wheelied whenever they let off and mashed the throttle..regardless the speed. For on road cars, you would need one helluva str8away to really appreciate it and most cars wouldnt have the room for it. Not to mention, ROAR standards probably will NEVER allow it anywhoos. Just my 2 cents.
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 11-27-2006, 06:57 PM   #40
wingswest328's Avatar
Send a message via AIM to wingswest328
Sorry for the Bump on this old topic but i was wondering if anyone ever tried that nova 2 speed. I have a brushless mamba 5700 system and saw that this was something possible and it might be better in brushless. Would it be something that is worth it or is it made just for a cool factor. I think it would be sweet but I dont want to go and screw up my brushless setup
wingswest328 is offline   Reply With Quote
