Old 12-28-2005, 09:15 AM   #1
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Default Which ESC to buy???
I am thinking about buying a new esc (currently have a GTB with 5.5 and I am not that happy with its braking ability - a bit soft for my liking).
Anyway, the esc I am looking at are: (in no particular order)
Tekin G11 Pro
Twister v2.1 (hara edition)
LRP Quantum 2 with worlds kit
Ko VFS-1 pro competition
Need something to handle touring car mod motors (mainly 7t in hot conditions 30'C ambient temps). I basically want something that is easy to use, robust, reliable, and adjustable (especially the brakes).
Any help or advice would be greatly appreciated.
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 12-28-2005, 09:17 AM   #2
Retard's Avatar
twister 2.1 and ko vfs pro com are the same
Retard is offline   Reply With Quote
Old 12-28-2005, 09:23 AM   #3
G-11 is bullet proof, although at them winds you MAY need to run a schottky diode on the motor, but then you might not, depends if you get any glitching. Very robust to and great customer service.
DA_cookie_monst is offline   Reply With Quote
Old 12-28-2005, 09:37 AM   #4
Send a message via AIM to David Alberico Send a message via Yahoo to David Alberico
go with Tekin. easy to use, sodier fuse, and easy to change wires
Castle Creations, J-Concepts, WMD Products, Clints Creations
David Alberico is offline   Reply With Quote
Old 12-28-2005, 10:39 AM   #5
Twin-Kyle's Avatar
Get the GTX.
LRP and digital servos don't get along very well.(glitching)
If you are using a spectrum,this will just make the problem worse from what I understand.
Twin-Kyle is offline   Reply With Quote
Old 12-28-2005, 10:53 AM   #6
Send a message via AIM to R/C Anonymous
the KO ESC's might require more then a few diodes with that motor...the KO diodes are rather $$$$$$$
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 12-28-2005, 11:37 AM   #7
I have a Tekin G10+ and its is great. It has run stock and an 8x1 mod motor perfectly. I run Spektrum and a KO 2123 digital servo. I've never had a single glitch. Even after running the 8x1 for 8 minutes straight with lots of hard acceleration and braking, the Tekin is cool enough to touch. Also, it does not require any big caps or heat sinks. From what I hear, the G11 is even better.
I think Tekin is the way to go.
Ira
iblumberg is offline   Reply With Quote
Old 12-28-2005, 08:00 PM   #8
Piyo Piyo's Avatar
Go for KO VFS-1 Competition.
It still has very high temp cut-off. Don't worry.
VIOLA ARIELLE & FLOREN ISABELLE
Piyo Piyo is offline   Reply With Quote
Old 12-28-2005, 08:04 PM   #9
has anyone tried the QC3
Fantomcat is offline   Reply With Quote
Old 12-28-2005, 08:09 PM   #10
well, for my it is very clear. Keyence is the best, followed by Novak and from a far distance LRP is third. And then the IPC series are "better" than the quantum series. (But the IPC has no outer wire connectors). The rest of the esc's (in my opinion) are just "populair"... but then again, i may be forgetting a brand aswell that in fact is up there with keyence and novak..,
Santosh is offline   Reply With Quote
Old 12-28-2005, 08:10 PM   #11
koabich's Avatar
Send a message via Yahoo to koabich
Originally Posted by Twin-Kyle
Get the GTX.
That's not a true statement. For myself along with countless others, that's all we've ever run and with no problems.
If you can wait, I would wait another month or so for the QC3. It has tons of changes to it and if nothing else, it coming to market should have the effect of lowering the price of the others you mentioned.
But you cannot go wrong with any of the ESC's you mentioned! Take a look at Novak too.
koabich is offline   Reply With Quote
Old 12-28-2005, 08:17 PM   #12
TEKIN G11
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 12-28-2005, 08:21 PM   #13
Tekin G-11
Hyper1 is offline   Reply With Quote
Old 12-29-2005, 03:05 AM   #14
Drewdc90's Avatar
I think the GTB brakes just fine and has alot more braking power than my LRP QC2. I had to set my braking to 15% when using a oneway but I only had to set it to 45% with my LRP. If your going to change I'd say the Tekin but I don't think you will get any more braking power out of it.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 12-29-2005, 03:45 AM   #15
Originally Posted by Jeff Cuffs
TEKIN G11
Hi Jeff,
Can you give me any feedback on the performance with the G11 pro?
Many thanks.
Leonard.
