Old 12-28-2005, 05:22 AM   #1
Default ESC Help
Hey guys I seem to be having some problems with my LRP AI Running Reverse whiles driving after about 5 mins it keeps cutting out and the car slowly comes to a stop the servo still works but no throttle? it has a built in fail safe so is it my radio or receiver? how can i test to make sure all is running right?. It also has to set itself up every time I start the car?
*sil80* is offline   Reply With Quote
Old 12-28-2005, 05:40 AM   #2
beer_drinker's Avatar
It could be that the ESC is overheating and shutting down, but then cooling down and starting up again. Try gearing down or using a slower motor and see if that solves/helps the problem.
beer_drinker is offline   Reply With Quote
Old 12-28-2005, 05:51 AM   #3
thanks mate ill give it a go. Im ruinning a kyosho outlaw 22x1 turn i thought the esc should be fine with that???
Old 01-01-2006, 06:07 AM   #4
i bought another esc off a mate (Nosram Patriot) and it worked great for 2 or 3 days then today i took my car out and it was going great then all of a sudden it slowed down completely to just a very very slow speed like i had a dead battery but it wasnt stopping then going like it does when the battery is dead. i had a look at the plug that goes into the reciever and it looked like those metal plates had bent and pushed in could this have caused the problem?
Old 01-01-2006, 06:26 AM   #5
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
It's either a False Peak, Dodgy Heat Thermal Sensors inside ESC, poor connection in Channel 2 (ESC) and maybe even between the motor/ESC.
I suggest using someone elses Reciever and replacing the ESC/Motor connections with Deans Plugs if you haven't already.
Team Duratrax is offline   Reply With Quote
Old 01-01-2006, 06:31 AM   #6
i have deans plugs fitted is it easy to replace the cord running from esc to reciever?
Old 01-01-2006, 06:34 AM   #7
pheyhoe's Avatar
R/C Tech Charter Subscriber
Are you sure the cells are charging correctly? It just sounds like your dumping....
I have an M.Troniks that cuts out when the voltage drops even if theres still enough capacity in the battery to finish a run. it will just reset and then start up again. But you say yours is slowing down as if the cells are dumping.... Maybe thats exactly what it is. Cells dumping.
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 01-01-2006, 06:40 AM   #8
the cells are 100% full it was running fine then about 5 mins after i switched it on it just pretty much stopped i took it home and charged the cells again then took the pinion off and it was spinning very very slowly like 1 turn per second
Old 01-01-2006, 06:48 AM   #9
mine does the same thing when the battery lewel is low
Rasmus TbEvo IV is offline   Reply With Quote
Old 01-01-2006, 06:53 AM   #10
Okay, when you first turn on the ESC, what happens when you give it input? Does the car begin to accelerate at all or do you have to give it a slight nudge to get it going?
Old 01-01-2006, 06:57 AM   #11
it doesnt do anything really it went very slow for a bit then was stopped by a small stone thats how slow it is
Old 01-01-2006, 06:58 AM   #12
team duratrax mine actually does that it is a mtroniks sonnik 4 sprint
Old 01-01-2006, 05:00 PM   #13
anyone? i need this running asap
Old 01-01-2006, 05:29 PM   #14
ok heres what you do you could (1) unsolder your motor plugs and rewire them because it sounds like your motor isnt recieving enough power,(2) Put everythign back together and go a lower pinion because it might be thermo cutout.
(3)Buy new brushes for the motor because i had this once it was a hung brush but it was slipping to the comm and then pullign away.
(4) if it still doesnt work i would go get someone else at th track to have a look at your charger or even try another battery because yours might be stuffed.
If it still doesnt work buy a new speedy ..........Novak GtX................
jamie814340 is offline   Reply With Quote
Old 01-01-2006, 05:30 PM   #15
Send a message via MSN to plucked_camel
Hey Guys,
I had one of these ESCs and had the same prob,
in my case it was the thermal protction cutting in because I had slightly overgeared
my motor. I changed my gearing to something really short and it was fine.
Hope this helps
Nick
plucked_camel is offline   Reply With Quote
