Old 12-27-2005, 11:04 PM   #1
Default Help on gear ratios
Hey guys im new to the forums and i need a bit of help,
I have got a yokomo bd and i used to run foams but have now changed due to track regulations can anyone give me soem setups for rubber tyres or a good gear ratio to run.
The track is ryper hobbies in wa its a tight and weavy track.
The motor i use is a monster stock 27 turn.
any help appreciated.
jamie814340 is offline   Reply With Quote
Old 12-27-2005, 11:21 PM   #2
Hi,
Regarding gearing,most people gear their car to suit the longest straight of the track.I don't race 27 turn,usually 23 turn.I gear my car at about 5.5 .I'm running on asphalt so maybe if I run carpet I'll gear some where a teeth 2 down to compensate for the extra grip and resistence carpet provides.
About setting up your BD,you can seach for the BD tread somewhere...
Ben.C is offline   Reply With Quote
Old 12-27-2005, 11:41 PM   #3
hey thankx for the reply but i have a question is the lower the gear ratio the hotter the motor will get, i am running a 23 pinion with a 78 spur wat would you recomend for me to use its a asphalt track and its very tight.
I have 1 more question to ask you the bed makes a slight clicking cross screech soudn when i accelerate but it goes away when i hit full throttle?
Old 12-27-2005, 11:43 PM   #4
sorry i mean the bd* not bed lol
bump
Old 12-27-2005, 11:44 PM   #5
Suspended
sounds like your belt is skippiong try tightining your belt
THE_REAL_FROBOY is offline   Reply With Quote
Old 12-27-2005, 11:45 PM   #6
ok i will try that thanks
Old 12-27-2005, 11:52 PM   #7
hey its not my belt its actually my tyres im runnign rubbers i know this because i took the tyres off and the noise stopped.
I put the front ones on and it still didnt make the noise then i put the rears on and it made the noise, could it be 1 of my rear bearings?
ohh by the way i changed rear tyres to see if it wasnt the tyre itself.
Old 12-28-2005, 12:11 AM   #8
I'm not familiar with the BD's internal gear ratio,so I can't help you here...
But how to get the final drive ratio is by using spur divide by pinon and times it with the internal gear ratio.Internal gear ratio is different from car to car...
About your clicking sound.Maybe you can check your spur whether is it warpped or is there a small pebble in between the spur gear teeth.If not maybe its the from CV jonts...Take out the CV joints and clean it and install back again.
Old 12-28-2005, 09:31 AM   #9
For gear ratio charts go here www.gearchart.com/
pops is offline   Reply With Quote
Gear ratios? mrmcphearson Rookie Zone 4 07-03-2008 08:21 AM
Gear Ratios/ Spur Gear Sparky7B Rookie Zone 2 02-26-2008 10:03 PM
Gear ratios N15M0 Rookie Zone 14 10-06-2005 05:36 PM
help with gear ratios! moot Electric On-Road 1 03-15-2005 02:43 AM
Gear Ratios.... Rain Rookie Zone 4 11-14-2003 07:23 PM
