Team CRC Gen X 10 R/T >
Like Tree61Likes
Old 01-18-2020, 04:30 AM
  #361
redmonster27's Avatar
Trader Rating: 34 (100%+)
The shims go under the castor blocks
redmonster27 is offline
Old 01-18-2020, 05:05 AM
  #362
Originally Posted by JeffofSpace View Post
Where do you adjust roll center on the car?
There is a optional shim set. The shims fit between the reactive block and the lower arm.
liljohn1064 and JeffofSpace like this.
old_dude is offline
Old 01-22-2020, 08:42 PM
  #363
JeffofSpace's Avatar
What are the kit side springs?
BTW...raced last weekend. Absolutely loved the car. Thanks for all your help. Went w 7k in side tubes (will try 5k next), kit springs front and side, purple center spring w 700cst, 1.5 camber...started with a hair of toe and ended up needing to go out to about 1.5. Fighting a ton of on power push...have gone to .45 front spring.
JeffofSpace is offline
Old 01-22-2020, 10:00 PM
  #364
I believe the kit springs are .50 I run 50s up front for more on power steering with little droop. Orange center spring and 27wt oil. I have the black super soft AE side springs wanting to say they are 1.9lbs spring rate I also run all the caster shims to the back with 10degree blocks with both roll center shims installed and 20k in side tubes. Locked rear axle my car is very aggressive hope this helps
NutDriver and JeffofSpace like this.
Old 01-23-2020, 06:58 PM
  #365
Forgot to mention I am running 5.2 in the front and 6 in the rear for ride height
JeffofSpace likes this.
Old 06-13-2020, 10:05 PM
  #366
Dan
Dan's Avatar
Trader Rating: 74 (100%+)
At the bigger races, are most people running the most narrow and shortest wheelbase possible on the front end?
Dan is offline
Old 06-14-2020, 03:20 PM
  #367
I run mine narrow and with short wheelbase. At this years Hudy all the CRCs I saw ran short and narrow. Don't know setups from the other big races.
Dan likes this.
sweems is offline
Old 01-09-2021, 12:57 PM
  #368
tdu verney's Avatar
Can you say how narrow?
tdu verney is offline
Old 01-09-2021, 09:59 PM
  #369
Just as narrow as will go...no shims on fronts.
tdu verney likes this.
Old 01-26-2021, 06:00 PM
  #370
R/C Tech Elite Member
Iím hoping someone can help me. I recently bought a brand new Gen-X R/T and am having some issues. I canít figure out how to adjust the camber. Iíve read the manual multiple times and have tried to find an answer on the forums and anywhere else. With no luck. This is my first CRC chassis so Iím not sure of all the ins and outs yet. Thanks in advance for any advice!
Nikolas8898 is offline
Old 01-26-2021, 06:10 PM
  #371
YoDog's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Nikolas8898 View Post
I’m hoping someone can help me. I recently bought a brand new Gen-X R/T and am having some issues. I can’t figure out how to adjust the camber. I’ve read the manual multiple times and have tried to find an answer on the forums and anywhere else. With no luck. This is my first CRC chassis so I’m not sure of all the ins and outs yet. Thanks in advance for any advice!
Adjust the pillow ball in or out of the upper arm to change camber. The manual doesn't really go into adjustments. I'm sure there are some how to vids on you tube though.
If you are wanting to adjust rear camber, I can't help you with that... LOL!
NutDriver likes this.
YoDog is offline
Old 01-26-2021, 06:17 PM
  #372
I will try that. Do you just put some shims in between the pillow ball and the upper arm? Iím definitely referring to the front lol.
Old 01-26-2021, 06:30 PM
  #373
The pillow ball head is threaded. Turn it in or out to adjust camber.
Nikolas8898 likes this.
mariob62 is offline
Old 01-26-2021, 06:43 PM
  #374
Ahhh. Yep that makes sense. Thank you!!!
Old 01-29-2021, 02:12 PM
  #375
when we ran the class here I did both the 5 and 10 degree blocks. Also always ran 45 springs front and side. Stayed with the kit center oil. As for springs started with the kit and went either way- depending on the tracks.Probably went with the short wheel base and narrow. For yoyr frontend adjustments you have to play with that till you find what is comfortable for you.
BullFrog is offline
