Old 12-27-2005, 04:13 AM   #31
asw7576's Avatar
It's okay buddy...... keep it cool.
Old 12-27-2005, 09:34 AM   #32
anthony390's Avatar
Send a message via AIM to anthony390
does ANYBODy know the answer to my question
anthony390 is offline   Reply With Quote
Old 12-27-2005, 10:09 AM   #33
asw7576's Avatar
plastic graphite molding is perfectly safe.
Old 12-27-2005, 10:16 AM   #34
anthony390's Avatar
oh ok thanks
so the one that cant touch the chassis is the woven graphite?
Old 12-27-2005, 10:32 AM   #35
asw7576's Avatar
oh ok thanks
yes.
Some high end receivers are immuned to radio interference even antenna wire touch the woven graphite. However we don't want to risk it, do we ? So cover it with shrink tube twice where it touches.
Old 12-27-2005, 10:37 AM   #36
anthony390's Avatar
yes.
oh i see thanks for the help
Old 12-27-2005, 10:43 AM   #37
Regional Moderator
Mark Mixon's Avatar
Default glitching
Motor is probably the most common cause, start there, then switch crstals, receiver, ESC, then transmitter to determine the culprit. Then replace that component only. If you don't have spares, borrow them or go to a hobby shop. Why try to mask the problem with kits, tape, foil, etc. Troubleshoot it, then fix it. Good luck, I know it can be frustrating. I switched to spektrum and have no worries. MM
FSEARA
"They may be toy cars, but I spend REAL money to race them!"- Racer X
"It's only a big deal if you make it one."
Mark Mixon is offline   Reply With Quote
Old 12-27-2005, 11:09 AM   #38
I've got to where I run caps on all my motors even if they have internal caps.If you don't want to go spectrum at least go PCM.
Hyper1 is offline   Reply With Quote
Old 12-27-2005, 11:42 AM   #39
scoobydo's Avatar
If your running an LRP Speedo with a combination of one of the New KO Servos, then you will get glitching.
Something to do with LRP not having a high enough BEC to run the New Programmable KO Servos.
Some people have had success with a cap, others have not.
I had to get an older KO servo as my QC2 would not work with the New KO I had.
scoobydo is offline   Reply With Quote
Old 12-27-2005, 03:21 PM   #40
jw92656's Avatar
Smile
Hello Killer89. Put my old radio into my mini cooper yesterday for my friend to run at SoCal. As mentioned, it has the Yokomo Noise Killer Kit installed. My friend never drove before but I explained that if the car started to drive on its own to pull off (freq conflict / glitching). SoCal was pretty busy yesterday and although he cracked the chassis hitting dots it never glitched on him. Here's what the cooper ran. Airtronics MX-3S 75Mhz. Airtronics 75Mhz Synth receiver. Novak GTX (cap removed). Airtronics 758 digital servo. Mabuchi motor. Even though it isn't a hot motor, I have everything stuffed inside the chassis so the ESC, and receiver are side by side. I'll be at SoCal running Mini tonight, and would be happy to show it to you. Look for a grey shirt, with the Michelin Man on the front :-)
jw92656 is offline   Reply With Quote
Old 12-27-2005, 07:52 PM   #41
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
Mark Mixon: I have changed motors, but i think ill change to one i was running in my other car with no probs...
Hyper1: no external caps works fine on my other cars, but i might try that...
scoobydo: not running KO... using hitec.. first servo was a 625, then a 645 currently..
jw92656: hmm... i might have to try that noise kit as a last solution... i cant make it to socal today... got surgery and cant drive... you race onroad only?
finally got pics:
killer89 is offline   Reply With Quote
Old 12-27-2005, 08:32 PM   #42
Suspended
is that a splice on the plug for the esc into the reciever. if it is chech those solder connections and make sure they are good and not touching each other
THE_REAL_FROBOY is offline   Reply With Quote
Old 12-27-2005, 09:00 PM   #43
rough512's Avatar
Try removing all of your electronics from the car. With the servo, battery pack, motor, esc and receiver connected together and powered ON, place these in a tray and try moving around the house and observe if you still glitch. This eliminates the chassis from the list of suspects. You can also do this at the track to check how the electronics behave in a noisy environment.
If you still glitch, try powering the receiver from an RX pack and instead of the esc, plug in another servo in slot#2. Check for any sign of glitch. If it does, try borrowing an RX (or a whole new radio system) from a friend.
If it doesn't glitch, borrow an esc then check. If the glitching stops, your esc may be damaged, check for damaged power wires and signal wires including the plugs.
If it still glitches with the new esc, then try a new motor.
rough512 is offline   Reply With Quote
Old 12-27-2005, 10:53 PM   #44
asw7576's Avatar
Could be transmitter, receiver or servo.
I suggest to change the servo and see what happen. If still glitch, I think you need to send RX and TX to Sanwa for repair.
Old 12-28-2005, 01:00 PM   #45
killer89's Avatar
thats only one wire thats spliced.. i spliced it, shrinked it and the shrinked the whole thing..
I think I finally got it... just ran the car out in the street. it seemed fine as long as i didnt get more than 100 ft away...
We'll see at SoCal though, because theres bound to be way more noise there...
I think changing the receiver and putting it on like 1/8 inch foam finally did it...
Any help appreciated for TT01 adrictan Rookie Zone 7 05-23-2008 08:35 AM
my servo is glitching at certain speeds, any help is appreciated :) halayli Electric On-Road 9 03-23-2008 01:49 PM
Returning to R/C - Advice Appreciated deafwish Electric Off-Road 0 01-21-2008 01:29 AM
Rb WS7 or Ninja, opinions appreciated. Kave Onroad Nitro Engine Zone 7 04-06-2007 02:47 AM
Making an RC Mug , Help Appreciated! budachi Malaysian R/C Racers 0 10-25-2006 02:39 AM
