what tire truer should i get
Hudy definitely
Even if you get the other ones, get Hudy arbors and carbide blade
check out the 3racing tire truer!!!! i own one and love it! full auto does everything a hudy does but is half the price! and it comes with the touring car arbor and the tire rounder! plus a super nice case!
3racing 229.00 at rc madness
i sent you a pm...you will like it when you get it! the rounder is a nice touch...no slop at all on my truer. i got mine from dinball r/c and after a rough start they did come through for me.
Originally Posted by Soviet
What a waste...truing all they way to 56mm to begin with. Try 57.5 or even 58 to start. It's still low enough to be fast.
-Sean
-Sean
For the record, I've currently got an Integy truecut-light lathe, and that thing can't trim more than maybe 0.5 mm of a purple touring car tire off at a time without bogging down or having to go very, very slowly across the tire.
The Integy Autotruecut truer is considerably faster to use, but I don't think that the motor is much stronger, if at all. But it's faster to use since the cutting arm is motorized.
Still, I think the OFNA and Hudy truers are supposed to be much stronger. Glad to hear the 3Racing motor is strong as well.
B
Team EAM
I have one of the newer style corally/ofna units and the new ones are a lot stronger than the previous ones. You can take off as much as you like in one pass.
I still want to get the 3 racing unit though...I just couldnt find one when I needed a truer and bought the corally/ofna to get me by.
EA
EA
Bob,
My Ofna eats foam tires for breakfast. It is cheap and fast working. If you are racing on Sunday I can show you as I will probably bring it up to Mikes.
Chris
Chris
