Old 12-25-2005, 02:01 PM   #1
big al's Avatar
Default OPINIONS--Auto battery VS. power supply
Hey my fellow RC'ers i'm doing an opinion poll: 12v auto battery or 12v power supply.
I've actually used both at the same venue and found that the cells charged with a 12v auto battery felt more punchy. Was it all in my head?? Gimme some knowledge!! Merry CHRISTmas--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 12-25-2005, 03:15 PM   #2
ChadCapece's Avatar
Yes, all in your head...
I figure a power supply is less likely to explode and spew battery acid on me, so that's what I use.
ChadCapece is offline   Reply With Quote
Old 12-25-2005, 03:18 PM   #3
Charles Leto's Avatar
Power Supply-maybe a lil' more money up front, last longer, all you have to do is plug it in when you need it, and its about a 16th the weight of a battery
Battery-more current avail, more maintenance, gotta charge it every now and then, a lot heavier, needs more storage area
i'd go power supply
Charles Leto is offline   Reply With Quote
Old 12-25-2005, 04:55 PM   #4
Most defintely go P/S,Like Chad said less chance of an accident,I have seen a battery blow up while it was being used on a dyno and it did do some damage,the user was VERY LUCKY,it only got on his leg and was able to quickly wash off the acid.
Hyper1 is offline   Reply With Quote
Old 12-25-2005, 04:57 PM   #5
Soviet's Avatar
The acid inside a battery isn't that dangerous fellas. You could dip your naked hand into a bowl of the stuff and wash it off several minutes later.
Of course that is a standard Car battery I'm talking about....
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 12-25-2005, 05:03 PM   #6
Yea! but I wouldn't want it in my eyes!
Old 12-25-2005, 05:04 PM   #7
ChadCapece's Avatar
http://www.batterycouncil.org/jumpstart.html
Old 12-25-2005, 05:12 PM   #8
i work on cars for a living, and Battery Acid is VERY dangerous, i know people who have had batteries in a car go up in front of them and its not pretty, destroys paint and metals, burns skin, loss of eyesight, not pretty at all,
Old 12-25-2005, 05:23 PM   #9
Al,
With any power supply, regardless of quality, you will get some sort of line noise. Because the filters can not filter out all of the noise. That is why some people use a power supply and a DC charger as opposed to an AC charger. They believe an AC charger doesn't have the abilty to clean up the AC noise as well as a power supply.
The battery is "Clean" DC voltage.
Now is it advantage?? I don't know...
What I do know is... that a battery is heavy and I tote a lot of other stuff to the track.
M2Racing is offline   Reply With Quote
Old 12-25-2005, 05:59 PM   #10
i agree with last post before this one
Turtlemaster is offline   Reply With Quote
Old 12-25-2005, 07:49 PM   #11
BATT_MAN's Avatar
Originally Posted by M2Racing
Al,
If a power supply is generating noise (ripple), it is not a high quality supply.
If it is generating noise, you can add a 10,000uf and above electrolytic power capacitor to clean it up.
The noise is called ripple, and as long as it is kept fairly low (just a few 10's mv ...lies) you should not have ANY PROBLEMS WHATSOEVER.
The voltage in a good regulated powe supply will be constant no matter the load. A battery will start decreasing the voltage as time and load increase. You have more possibilities of false peaks and problems from a voltage drop at the battery than from low ripple generated by a PS.
Not to mention the weight (like every body says) and the pssibilities of an accident.
BATT_MAN is offline   Reply With Quote
Old 12-26-2005, 01:22 AM   #12
Soviet's Avatar
It's the explosive venting and hot acid that cause more damage. The acid inside a car battery is only 1/3rd Mole HCL. I've washed lab-glassware in 1/2 Molar HCL and gotten it on my hands. Washed it off a couple mins later and only minor skin burns.
Point is that as far as RC is concerned...a 12v car battery will work just fine...it's just too heavy to be of any real use.
-Me
LiPo Battery, Charger, Balancer & Power supply II Fast R/C Items: For Sale/Trade 45 07-24-2008 05:42 PM
Does 12v power supply affect the battery charging? straightaway Electric On-Road 15 03-09-2007 04:37 PM
opinions on integy auto tire truer v2 sukh Electric On-Road 15 01-24-2007 08:28 PM
Charger/Power Supply/Battery Question!! slbks5 Electric On-Road 2 06-23-2006 09:09 AM
Battery charger hook to power supply question SteveB Rookie Zone 4 03-24-2005 12:22 PM
