Old 12-24-2005, 07:24 PM   #1
Drewdc90's Avatar
Default GTB seems slower
Hi
I've been testing a few setups with my car and it seemed really slow, the car seemed to take corners that I usually have to slow down for at full throttle. I had a look inside and the kevlar wrapping looked like it was starting to come off. I cut the little bits that were hanging off. That didn't seem to help. I checked the bearings and they were fine.
Any help would be great.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 12-24-2005, 09:38 PM   #2
Maybe you can give Novak an email...They should be able to help you out.
One of the Best custormer service.
Ben.C is offline   Reply With Quote
Old 12-25-2005, 01:16 AM   #3
AngryAsian's Avatar
Mail. charlie at novak.
I've been surpised time and time again with their customer service. These guys are great.
How did you go with the glitching issues?
I assume you've checked all the wiring, the power cap(does the esc feel a bit "soft" on punch?, does it get warmer than usual?)
I have noticed on hot days, the motor does heat up a little and performance drops appreciably. Give it a shot with some co2 spray and you'll notice the speed difference.
AngryAsian is offline   Reply With Quote
Old 12-25-2005, 03:16 AM   #4
Drewdc90's Avatar
The esc doesn't really seem to have less punch but the motor is really lacking top end. I will have the clitching sorted out as soon as I get my spektrum. I'll email charlie and see how I go. Thanks.
Old 12-27-2005, 02:39 PM   #5
Drewdc90's Avatar
I tried running a brushed 10t motor and it ran slower as well. I then tried a another brushed motor with a QC2 in a different car and it also run slow. I think is my batteries or somthing.
Old 12-28-2005, 04:02 AM   #6
AngryAsian's Avatar
here's my 5min checklist..
Car - belts binding, bearings, cvds, diffs, shimming, wheels rubbing on suspension arms, wheels on body
Batts - voltage and temp
Charger - is it working?
Radio - expo set to 0, EPA set to zero,
Old 12-28-2005, 04:05 PM   #7
Drewdc90's Avatar
I ran the car with the GTB the day after which wasn't as hot and it seemed a lot better. I've mounted a fan next to the motor, I'll see how that goes. Thanks.
Old 12-28-2005, 07:31 PM   #8
Drewdc90's Avatar
The fan keep the motor cool but didn't make it go any faster. I ran a stock motor and it seemed like a 540. I don't think it's my charger because it says the batteries put a good charge (9.145 V) but in both of the car's all of them go slow. The connections are corally style pulgs that I put on about a month ago so I don't think it is the connections. What else could I check?
Old 12-28-2005, 11:09 PM   #9
Lokanas's Avatar
try another speed control if you have - at least you will know which link in a chain is weak. I hope this isn't your case but usually semi-burnt esc's are going slower as part of the FET's are dead. Of course as it is GTB there might be something else. You should contact Novak anyway.
Lokanas is offline   Reply With Quote
Old 12-29-2005, 02:59 AM   #10
Drewdc90's Avatar
I've tried another speed contoller and it also went slow. I'm going to the track this weekend, I'll compare my car and my mates and try different batteries and what not. I'm starting to think there is no problem it just me getting used to the speed of racing mod.
Old 12-29-2005, 03:38 AM   #11
whoopass's Avatar
Sounds like you have checked the lot except the transmitter.........
whoopass is offline   Reply With Quote
need help going slower - crazy, I know masterjer Rookie Zone 10 08-26-2011 09:17 AM
T4 Slower Than Normal whitty Electric Off-Road 8 06-20-2008 09:06 PM
The site slower than shit! BuggyKing R/C Tech Site Forum 2 12-12-2006 01:49 AM
D5 Slower Than P2K2 jackv202 Electric On-Road 6 09-10-2003 02:30 PM
