Old 06-14-2016, 01:14 AM   #1
Default Wheel well cutting
How do you do it?? Looking for some tips
bLamey470 is offline   Reply With Quote
Old 06-14-2016, 02:18 AM   #2
Use a compass cutter. When painting leave the center of the wheel wells clear, so that you can see the axis when fitting the body on the chassis. Then just pin the compass cutter to that point and cut a nice round wheel well. Use a slightly bigger diameter than the wheels.
perzeus is offline   Reply With Quote
Old 06-14-2016, 02:48 AM   #3
dan_vector's Avatar
Trader Rating: 27 (100%+)
Compass cutter or in a pinch draw around a wheel and cut slightly larger with curved scissors. When using a compass cutter 5mm diameter larger than the wheel is usually good enough to provide enough clearance.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 06-14-2016, 08:47 AM   #4
Bar
Schumacher wheel jig, I love it, I have tried the compass cutter in the past which is a pain in the ass, really happy with it like many others
http://www.racing-cars.com/pp/Old_Ca...i-3/U4806.html
Luke Burr
Bar is offline   Reply With Quote
Old 06-14-2016, 09:16 AM   #5
niznai's Avatar
The schumacher jig only helps you draw the cut line, but not to actually cut it. In fact I don't see why you can't make your own out of cardboard or whatever instead of paying money for something that doesn't do anything else.
I use a compass cutter, it is slow, but it yields the best results.
The trick is to not try to cut through the shell, but to scratch it, so spin the compass so the back of the blade is doing the work. That way, the point of the blade will scratch progressively deeper into the plastic until it goes through. Don't push too hard, let the point do the work. I recommend taping the wheel arch with masking tape beforehand just in case.
To find the centre of the wheel well, just put the shell on, turn on your radio and with the wheels straight push the shell hard enough against the end of the axle. I actually hit it sharply but not hard with a soft screwdriver handle. It will leave a clear dent/mark. The rear wheels don't need the radio on.
You don't really need to finish the cut, but I do round both edges (inner and outer) of the cut with fine sandpaper. That way it's less likely the shell will catch in the wheel. I usually have only about 2mm of wheel clearance and never had problems with body stuck in the wheels plus it looks really schmick.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 06-14-2016, 09:43 AM   #6
RobS's Avatar
Mount the body on the car with tires on the car, then line up another tire on the outside of the body and trace a line around it. Then cut around the outside of the line for a little bit of extra clearance. Then use a standing drum (link below) to make perfect round edges.
http://racepf.com/accessories/better...-sanding-drum/
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is online now   Reply With Quote
Old 06-14-2016, 09:51 AM   #7
TOM MAR's Avatar
I mount the body & mark the center. Then use one of these..
http://www.walmart.com/ip/Compass-Cu...ingMethod=p13n
Trim with scissors as needed.
TOM MAR is offline   Reply With Quote
