Old 01-16-2006, 10:04 AM   #106
Rick Hohwart's Avatar
Originally Posted by John Stranahan
Rick-Have you guys tried putting one of these platimum LiPos in a Losi JRXS. I have a report from a fellow that could not get it in his car. It did not reach the point of touching the foam pads.
I personally have not done so. But we have sent batteries to those manufacturers who have requested them (including Team Losi) to check fitment and for consideration when designing new cars and to make required modifications to existing cars.
Todd Hodge has been playing with a pack. By contacting Team Losi, a driver may be able to find out exactly what needs to be done to make it fit in the existing car.
Rick Hohwart is offline   Reply With Quote
Old 01-16-2006, 10:09 AM   #107
How is the handling of a LiPo in a B4? I would like to know if I need to make any huge changes to my buggy before I buy a LiPo. Any out of the ordinary changes I need to make?
Vahe is offline   Reply With Quote
Old 01-16-2006, 10:18 AM   #108
You will need to make no changes for a B4 other than possibly changing the foam blocks to ensure a tight fit. Ryan Cavalieri and Joe Pillars have been using them in their B4s during SoCal Raceway club races.
Old 01-16-2006, 10:22 AM   #109
Thank's Rick
Old 01-16-2006, 11:11 AM   #110
Trader Rating: 27 (100%+)
Send a message via AIM to John Stranahan
Rick-Thanks. I wil relay the information.
John Stranahan is offline   Reply With Quote
Old 01-16-2006, 11:54 AM   #111
jhigga15's Avatar
Charokee wins the award of longest 1st post!!!
jhigga15 is offline   Reply With Quote
Old 01-16-2006, 12:13 PM   #112
jhigga15's Avatar
I think that this battery will fall out of the tourning cars b/c it does not sit in the battery slots
Old 01-16-2006, 12:14 PM   #113
kufman's Avatar
These packs should work perfectly in my XXX4. It is a little battery side heavy with NiMH cells, so this will be good. Put the Lipo together with my schultz/lehner combo and I will be able to run around the dirt for a long time.
plate carbon chassis cars may have some trouble, but there are some easy ways to fix it. Cars with tub style chassis will work great (TC3/4, XXXS, Ta-04, ta05 ..... etc). I have seen people buy several battery straps and glue a pack to each one. Seems to work fairly well.
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Old 01-16-2006, 05:17 PM   #114
For stock brushed motor racing wouldn't the Lipo be at a disadvantage due to it's slightly lower voltage when charged? For instance my race time peak voltage is 8.5-9.1 volts depending on the pack.
mguebert69 is offline   Reply With Quote
Old 01-16-2006, 06:03 PM   #115
Is there a way some sort of cut-off can be attached? (Like the built in Low Voltage Cutoff with FMA's Scorpion packs?). At $125 a pop, it would be good to know when to stop driving.
Also, what if you have a two battery setup (i.e., eMaxx, other monster trucks). Wouldn't it be harder to notice if the "truck has started to slow"? I mean, if it slows, by that time, wouldn't it be possible for one pack to be weakening, and the other already over discharged? In which case, a Low Voltage Cutoff would be a good idea...
Alfalfameister is offline   Reply With Quote
Old 01-16-2006, 06:08 PM   #116
AdrianM's Avatar
The R/C car LiPos have a higher nominal voltage and lower IR's so they will make any motor go faster. Peak voltage is not important.
For normal non-lipo batteries the lower the battery peaks the better. This means the internal resistance is low and the pack can better give up its energy.
Adrian Martinez
Old 01-16-2006, 06:51 PM   #117
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
I just got one...and according to the instructions...yeah, you can wait until it starts to slow...but you're better off if you say stop at 15 minutes or so and charge it, rather than taking it all the way to the limit. I mean, you get some pretty crazy run time out of it, so there's no reason to take it to the very edge.
I have it in my ZX-5 and it fits great. I just turned the outer battery tabs around and they fit the pack like a glove. I'm going to get another one.
Turbo Joe is offline   Reply With Quote
Old 01-16-2006, 07:58 PM   #118
We began testing them last week in our Masters class. All I can say is WOW. Stock buggy or truck felt like a rocket compared to our race packs. Ran the Batts for two qualifiers before we charged them, and no drop off at the end of the second heat. I'm Sold even though I can't get my current Advantage charger updated for lipo's.
Mark O'Brien is offline   Reply With Quote
Old 01-16-2006, 10:54 PM   #119
Your best bet is to use an ESC with an adjustable voltage cutoff.
Old 01-16-2006, 11:26 PM   #120
PitCrew's Avatar
I understand what your saying, but the LiPo's nominal voltage is 7.4...
Even after I run a 5 min race in stock sedan, and start discharging my pack, say on my pulsar at 10 amps, just so I can see numbers, the pack is still putting out over 8 volts (at 10 amps after a 5 minute race). I have to believe that the pack is putting out at least close to 8 for the first few minutes in stock.....
Making a direct comparison by just switching the batteries isn't really fair because the weight of the LiPo's are so much less. So of course the car is going to go much faster, and get their quicker. If you really want to compare apples to apples, you gotta add weight to the car so it equals the weight of the car with a Nimh pack in it.
Maybe the rules for weight will be reduced though, allowing a ligher car. Then it would be sweet!!
PitCrew is offline   Reply With Quote
ORION PLATINUM 4800 LIPO sedanracer8 R/C Items: For Sale/Trade 21 12-18-2007 08:09 PM
>>> Orion Platinum 4800 Lipo <<< rraden R/C Items: For Sale/Trade 9 10-22-2007 09:55 AM
Is the Mamba Max 7700 to much for the Platinum 4800 Lipo _pilot_ Electric On-Road 2 10-10-2007 01:52 PM
Team Orion Platinum Lipo Pack danjoy25 Australia For Sale/Trade 0 05-10-2006 04:26 PM
FS Orion Platinum Lipo!!! Glowster21 R/C Items: For Sale/Trade 20 04-05-2006 06:37 PM
