Old 05-28-2007, 05:11 PM   #1096
Nexus Racing's Avatar
MrBlack (or someone in-the-know),
I accidentally ran one of my platinums below the 6V cutoff...I rushed it to the charger right away and it showed 5.3V at the start of the charge.
It still took a 4787mah charge (same as it normally would take) and the cells still show a perfect balance with a multimeter...are there any other symptoms that could tell me whether or not I damaged the pack?
Also, what actually suffers when the "irreversible chemical reaction" takes place? run-time? avg voltage?
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 05-28-2007, 05:54 PM   #1097
Charge with the balancer at a very low amp rate around .3 amp to allow it to charge/balance real slow.
If something is wrong it will swell up! Do not charge and in fact get the energy down in the battery to send back to manufacturer for inspection.
Tired of high priced gasoline!
Go here to help out: http://www.americansolutions.com/
Craps is offline   Reply With Quote
Old 05-28-2007, 06:13 PM   #1098
MrBlack's Avatar
Hello Nexus,
Based on the specs given it sounds like you are OK , lucky but OK.
I have actually taken then down to as low as 4V ans been able to recover then this is rare and also very lucky.
5.3V is just below the 5.4V low spot that we recommend with our cells.
If the the cells are damaged symptoms are a loss of performance ( ie. capacity, voltage) in extreme damage conditions they will even swell.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 05-28-2007, 06:16 PM   #1099
MrBlack's Avatar
Originally Posted by swopemike
[ edited : I put this question in the Advantage thread where it belongs .... ]
Question for Orion:
Hypothetically, if you made a 6000+ maH LIPO pack... would the Orion Advantage Carbon charge it OK?
Also, what happens if you had a NIMH2 battery require more than 5400 on a charge?
Of course.
Old 05-30-2007, 05:04 AM   #1100
racer34v's Avatar
Trader Rating: 126 (100%+)
Send a message via Yahoo to racer34v
how do you balance these packs? i havent seen one in person and i cant sem to find whose balancer the ports are made for..?
thanks
racer34v is offline   Reply With Quote
Old 05-30-2007, 06:46 AM   #1101
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Thumbs up
2mm bullet connector on the bottom of the pack, but as stated in many other posts here by Orion guys, these packs will rarely, if ever, need to be balanced. It isn't something I would worry about, really.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 05-30-2007, 07:12 AM   #1102
Originally Posted by AdrianM
When the charger switches from CC to CV charging the battery is ~80% fully charged and it is fine to run it. However, you will get more power if you let it completely charge.
I think this statement is only true if you use 1C charging. At 2C rate you are nowhere close to 80% when the charger swithces to CV.
cvt01 is offline   Reply With Quote
Old 05-30-2007, 10:42 AM   #1103
MrBlack's Avatar
thanks
http://www.teamorion.com/FAQ/Balancing+LiPo
Old 05-30-2007, 11:04 AM   #1104
swopemike's Avatar
...if you made a 6000+ maH LIPO pack... would the Orion Advantage Carbon charge it OK?
Originally Posted by MrBlack
Of course.
What I meant to ask was, could you fully charge a >5400 mAh pack on a single charge cycle. I was told that all battery types were limited to 5400 mAh on the Advantage. So I assume for a big LIPO pack you would have to restart the charging (no big deal, just adds another step).
Is there indeed a mAh limit for a single LIPO charge cycle?
swopemike is offline   Reply With Quote
Old 05-30-2007, 11:30 AM   #1105
racer34v's Avatar
Apex, I thought that name/car combination was familar. Are you running one in anything??
Thanks mr black, thats what i was after, looks too simple not to be using one of these packs, will be ordering one this afternoon!!
Alan
Old 05-31-2007, 10:01 AM   #1106
MrBlack's Avatar
The Mah limit is the same for all batteries 5400mAh.
This is the amount put in not the limit on the size it can charge for instance many times when you recharge say a 3200mAh LiPo when you are done charging it does not take 3200mAh to fill it as you are only putting back into it what you took out.
Old 05-31-2007, 10:48 AM   #1107
squarehead's Avatar
I have two, and they fit in all of my cars except my BJ4WE. They fit perfect in the oval cars, though few places around will allow them yet. The fit in the off road cars is great, too, and my new JRXS-R seems to have been designed around one, so it fits like a glove.
The future is here.
Everything depends.
Nothing is always.
Old 06-01-2007, 01:37 PM   #1108
MarkBrown's Avatar
Default Anybody working on a quick-change for platinum lipo?
With Team Orion setting the standards for lipo dimensions and electrical connections, it seems there is now a greater opportunity for RC car makers like Associated, Losi, Tamiya, XRay, etc to provide quick-change battery mechanisms in their car designs. Electric main events could be longer, comparable to gas main events. I think this would be popular, especially with the hardcore racer types who are early adopters of lipo. Obviously it would benefit Team Orion by selling more lipos!
Is this something that Team Orion is actively promoting, with sample designs, etc?
Perhaps Kyosho can lead the way in this area with their car designs?
--mark
MarkBrown is offline   Reply With Quote
Old 06-02-2007, 11:39 AM   #1109
Im not sure why my motors have been running so hot lately but I have noticed that the heat from the motor is transferring heat to the battery. The battery is coming off warm now after every run. Im about 99% sure its due to the motor and not the battery.
Would this harm the battery in any way?
Theres no visible swelling, the performance of the battery doesnt seem to be affected, its charging normal as usual.
wcalaker is offline   Reply With Quote
Old 06-04-2007, 07:13 AM   #1110
Leodis's Avatar
Trader Rating: 16 (100%+)
Any update on the "heavy" lipo?
Would it be appropriate to go ahead and make a thread about it in the electric off-road section?
Leodis is offline   Reply With Quote
ORION PLATINUM 4800 LIPO sedanracer8 R/C Items: For Sale/Trade 21 12-18-2007 08:09 PM
>>> Orion Platinum 4800 Lipo <<< rraden R/C Items: For Sale/Trade 9 10-22-2007 09:55 AM
Is the Mamba Max 7700 to much for the Platinum 4800 Lipo _pilot_ Electric On-Road 2 10-10-2007 01:52 PM
Team Orion Platinum Lipo Pack danjoy25 Australia For Sale/Trade 0 05-10-2006 04:26 PM
FS Orion Platinum Lipo!!! Glowster21 R/C Items: For Sale/Trade 20 04-05-2006 06:37 PM
