Old 04-03-2007, 09:10 PM   #991
Grenade10's Avatar
Trader Rating: 37 (100%+)
Originally Posted by wallyedmonds
i dont know if its been said here or not but is there a lipo battery for 1/12
one that will go in the GEN X if so that would be so sweet.
or i should say
very nice.
I would also second that. I also would purchase a saddle pack for my 1/10 scale pan car!!
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 04-03-2007, 09:24 PM   #992
Iceracer's Avatar
Another request for a split pack for pan cars. And make it so that the two split pieces can also fit tightly back together and be used in place of a standard side by side as well. That way it can be dual purpose.
Iceracer is offline   Reply With Quote
Old 04-04-2007, 08:49 AM   #993
UN4RACING's Avatar
Trader Rating: 22 (100%+)
OK!
Last Tuesday I fully charged both of my 1 year old platinum 4800's.
They sat all week till yesterday, I then tested them for voltage.
They both were 8.30 volts, Then I tested them for balance they both were 4.15 volts. I did the balance test with a cheap radio shack volt meter.
Neither packs have ever been balanced. I was supprised to have perfect identical numbers. Did I test these correctly or is there a better way to test?
If I did it correctly and the numbers are right?
I"M LOVING IT!
P.S. I have babied these cells for a year, at this rate I will never need new cells.
I'm fixing to turn loose some serious abuse on them this summer.
I'm ready for some of those new 6000 MAH's that I heard of?
UN4RACING is offline   Reply With Quote
Old 04-04-2007, 08:59 AM   #994
Me too, just make the height two milimeter less than 4800 so it would fit in the damn xray 007
cvt01 is offline   Reply With Quote
Old 04-04-2007, 09:59 AM   #995
syndr0me's Avatar
Trader Rating: 32 (100%+)
Losi and Schumacher have managed to engineer their cars to accept this pack. It seems like an XRay chassis that's been milled down to handle a square pack would solve the problem.
syndr0me is offline   Reply With Quote
Old 04-04-2007, 10:22 AM   #996
AdrianM's Avatar
I have been using LiPo for ~3 years now in R/C planes and helis. As long as you never discharge below 3v per cell or over 4.2v per cell, the cells never get hot enough to puff up (over 150*F) they will last a VERY LONG time. In 3 years I have only killed 3 packs. All were done in by storing them at 100% charge for ~10 months. Now I know you can only store them at 50-80% charged.
I have packs that get used several times per week each that are over 2 years old and they are still good.
I got a balancer a couple of years ago but I never use it becuase the cells are balanced every time i check them....even the old ones..even the ones that got puffed a little on a hot day in my Trex 450
Adrian Martinez
Old 04-04-2007, 10:30 AM   #997
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
I'm just wondering how you guys know exactly how much charge is in each pack in order to store at 50% to 80% charge?
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 04-04-2007, 10:55 AM   #998
AdrianM's Avatar
I use the Duratrax Ice charger. When setting up a program to charge any battery you have to put in the battery capacity and on another line the percentage of capacity allowable to put into a pack (10%-150%)
I know in a 6 min flight I use 1600mah out of my 2100mah packs, 80% of the batteries capacity.
I set my charger to put only 50% of 2000mah back into the pack. That leaves my packs ~70% charged.
Adrian Martinez
Old 04-04-2007, 11:22 AM   #999
squarehead's Avatar
Gotcha. Pretty simple. Thanks Adrian.
Everything depends.
Nothing is always.
Old 04-05-2007, 02:33 PM   #1000
MrBlack's Avatar
OK!
I"M LOVING IT!
Yes you did this correctly.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 04-05-2007, 02:34 PM   #1001
MrBlack's Avatar
Kokam has recommended to us that storing them above 50% is ideal and storing them at 100% is even batter as the chance of them falling below %50 do to extended storage is less of an issue.
I store my batteries personally at %100 and I run them weekly.
Old 04-05-2007, 03:07 PM   #1002
MrBlack,
Could you please post a 30A discharge curve of the platinum lipo?
Old 04-05-2007, 05:44 PM   #1003
DriftDreamer06's Avatar
i have tried to find info on the connector that would be used on the platium balance port? does any body now what that connector is and where i can get some on line? thanks for any help.
DriftDreamer06 is offline   Reply With Quote
Old 04-05-2007, 06:08 PM   #1004
Nexus Racing's Avatar
It is a 2mm connector. Here is the Team Orion plug that we offer, along with the reprinted installation instructions provided by MrBlack:
http://nexusracing.net/product_info.php?products_id=893
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 04-05-2007, 06:08 PM   #1005
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Damn...that sounds like just what I said...LOL
Turbo Joe is offline   Reply With Quote
ORION PLATINUM 4800 LIPO sedanracer8 R/C Items: For Sale/Trade 21 12-18-2007 08:09 PM
>>> Orion Platinum 4800 Lipo <<< rraden R/C Items: For Sale/Trade 9 10-22-2007 09:55 AM
Is the Mamba Max 7700 to much for the Platinum 4800 Lipo _pilot_ Electric On-Road 2 10-10-2007 01:52 PM
Team Orion Platinum Lipo Pack danjoy25 Australia For Sale/Trade 0 05-10-2006 04:26 PM
FS Orion Platinum Lipo!!! Glowster21 R/C Items: For Sale/Trade 20 04-05-2006 06:37 PM
