Old 08-05-2006, 07:51 AM   #871
XrayFK's Avatar
Originally Posted by marvi
3. is balancing absolutely necessary? ive read somewhere that you have to do this at least once every 30 runs. is this 30 complete cycles (fully charge, use until it almost dumps, then charge again)? or 30 charges (full or half charge, full or half use)? what happens to the pack if i dont balance it?
1 charge cycle means using all of the battery's power, but it doesn't have to be in one charge/discharge. For example, if you charge the Lipo and run it down to half of its capacity, then charge it again and do the same thing; that is one cycle.
XrayFK is offline   Reply With Quote
Old 08-05-2006, 07:47 PM   #872
Trader Rating: 69 (100%+)
thanks for the info
i posted this in the futaba cdr5000 thread, but hope you guys may also know the answers...
is there a way to charge lipos on this charger? among the available settings (voltage cutoff, capacity, etc... ), can i create a charge profile safe enough for lipos?
marvi is offline   Reply With Quote
Old 08-06-2006, 12:45 AM   #873
Trader Rating: 18 (100%+)
no, you can not use the cdr-5000 to charge lipo's. Lipo chargers use constant current/constant volt (cc/cv) for charging. In the platinum at 1c charge rate, it needs to be charged at 4.8 amps until the pack reaches 8.4 volts, then the amp rate goes down while the voltage remains the same. You can not safely use a charger in delta peak mode to charge a lipo.
Warning, the following is not suggested. Doing what I am about to say may result in fire. Alright, if you are extremely careful, you can charge on a nimh charger. BUT you must stop the charge cycle when the voltage reaches 8.4 volts on the platinum. Note, the battery will not be fully charged and if you go over 8.4 volts well that is bad. Again this is not suggested, and I would not try it anywhere but a fire control area, and make sure you have an extra $135 for the battery you will need when you ruin your old one.
trilerian is offline   Reply With Quote
Old 08-06-2006, 01:21 AM   #874
H I
H I's Avatar
Can someone tell me how you balance lipo battery?
I got ICE charger, can balance be done with this?
H I is offline   Reply With Quote
Old 08-06-2006, 04:03 AM   #875
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Originally Posted by MR JOLLY
Dewalt,Bosch,Hilti,etc have/are all going over to Li-Po to power there cordless range of Hammer drills,etc & these hammer drills pull lot`s of amps without to much grief
also if the power tool industry are going over to Li-po /Li-Mn then could this spell the end for c-cells makers
c-cell market is for the power industry with RC racing as a spin off ,they are moving on to Li-Po
food for thought
i`m changing my mind on this
just done some home work & the battery company`s actually do make sub c-cells for RC use ,so this c-cell battery war will keep going on i`m afriad
IE;;put these RC cells in a torch it doesn`t work coz the positive button has been recessed to fit in RC cars
learn some thing every day (i`m willing to learn though others are just so blinkered they are scared of being wrong
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 08-06-2006, 05:55 AM   #876
Originally Posted by trilerian
no, you can not use the cdr-5000 to charge lipo's. ...
thanks again for the info well, better be safe than sorry
Old 08-11-2006, 09:42 PM   #877
CRASH's Avatar
Trader Rating: 26 (100%+)
Default Connectors
What other connectors fit besides the Orion plugs? No one has the orion plugs in stock.
Thanks,
CRASH is offline   Reply With Quote
Old 08-11-2006, 09:44 PM   #878
syndr0me's Avatar
Trader Rating: 32 (100%+)
Thanks,
http://www2.towerhobbies.com/cgi-bin...4&I=LXTJ25&P=K
syndr0me is offline   Reply With Quote
Old 08-11-2006, 09:46 PM   #879
CRASH's Avatar
Thanks,
Old 08-12-2006, 01:42 AM   #880
MR JOLLY's Avatar
any 4mm plugs will do ,corrally ones are the same
does not have to be orion made !
Old 08-12-2006, 08:09 AM   #881
You are right in everything what you have said. However AFAIK the CDR-5000 can be adjusted to cut off on a certain voltage. So you can adjust to end the charging process at 8.4V. Using this method you can charge them up to 90%.
NOTE: THIS IS ALL THEORY I'VE NEVER TESTED IT.
cvt01 is offline   Reply With Quote
Old 08-20-2006, 02:52 AM   #882
guys,
I am thinking about balancing my platinum lipo using my avionics charger via the 2mm male pin. should i set the charger to 3.7 or 7.4 volt?
azmio is offline   Reply With Quote
Old 08-21-2006, 06:38 AM   #883
3,7 volt
barclayrc is offline   Reply With Quote
Old 08-21-2006, 07:59 AM   #884
bvoltz's Avatar
Trader Rating: 44 (100%+)
Does anyone know where I mite find 90 Degree male pins to contect to the Speedo. In my FT TC4, the upper deck is in the way and I need to either hang the battery out the side, or find a better way to connect....
bvoltz is offline   Reply With Quote
Old 08-21-2006, 08:39 AM   #885
Rick Hohwart's Avatar
You can solder the ESC leads to the end of the plug at 90 degrees. In fact, many do this anyway whether they need this angle or not.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
ORION PLATINUM 4800 LIPO sedanracer8 R/C Items: For Sale/Trade 21 12-18-2007 08:09 PM
>>> Orion Platinum 4800 Lipo <<< rraden R/C Items: For Sale/Trade 9 10-22-2007 09:55 AM
Is the Mamba Max 7700 to much for the Platinum 4800 Lipo _pilot_ Electric On-Road 2 10-10-2007 01:52 PM
Team Orion Platinum Lipo Pack danjoy25 Australia For Sale/Trade 0 05-10-2006 04:26 PM
FS Orion Platinum Lipo!!! Glowster21 R/C Items: For Sale/Trade 20 04-05-2006 06:37 PM
