Old 07-12-2006, 10:28 AM   #781
Rick Hohwart's Avatar
Originally Posted by syndr0me
Yea, no doubt Rick, incredible job at the worlds.
The new pack sounds like what we (the touring car crowd) were hoping for. If that sucker will sit down in normal battery slots, it's going to be a dream come true. I'm holding out a small hope that it'll have multiple power connectors so I can connect to it on the corners like a normal side-by-side pack, but I won't get greedy. :-)
Thanks to you too!
Your dream has come true although multiple power connectors are not included:-)
Rick Hohwart is offline   Reply With Quote
Old 07-12-2006, 10:36 AM   #782
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Rick Hohwart
Thanks to you too!
Rick
will i be able to use the small corally connectors? hopefully i can get a sneak preview this sat at Tamiya? thanks!
- chris
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-12-2006, 10:38 AM   #783
Originally Posted by Hebiki
Rick
- chris
I am not sure what the small Corally connectors are. It uses the same connectors as the Platinum but not sure if those are what are considered the small ones.
Yes you can see (and hold) the pack and see it run on track.
Old 07-12-2006, 10:40 AM   #784
Default m8-m11
Rick
I saw in one of the magazines that you have an aftermarket wheel on your radio. How is it dimensionally different and is it available to the public? Iím looking for something slightly smaller in diameter and a little deeper to keep my fingers from hitting other buttons.
Thanks, Greg
Davenport is offline   Reply With Quote
Old 07-12-2006, 10:43 AM   #785
Hebiki's Avatar
those are considered the "large" connectors. i think rod c. uses (small connectors) them in his car also. the male connectors allow you to install the wiring at a 90 deg angle.
here's a pic.
Hebiki Design Works
Old 07-12-2006, 10:45 AM   #786
those are considered the "large" connectors. i think rod c. uses them in his car also. the male connectors allow you to install the wiring at a 90 deg angle.
here's a pic.
It takes the larger ones only.
Old 07-12-2006, 10:52 AM   #787
Originally Posted by Davenport
Rick
Thanks, Greg
It is the same diameter but moves the wheel away from the radio case so that you do not have to worry about your fingers hitting any buttons. It is not what you would consider readily available, but you can PM Steve Chamberlain (SCIDA) to buy one. I think he has some in stock.
Mark Pavidis and some other pro drivers use this wheel as well.
Old 07-12-2006, 11:23 AM   #788
syndr0me's Avatar
Trader Rating: 32 (100%+)
Will these connectors work?
http://www2.towerhobbies.com/cgi-bin...?&I=LXTJ25&P=M
I always hear about people calling these "Corally" plugs, but I've never found a good source for them.
syndr0me is offline   Reply With Quote
Old 07-12-2006, 11:34 AM   #789
Mr. McGoo's Avatar
yes those will work, that is the exact ones i purchased from Tower....
XRAY | RCAMERICA | HUDY | Team Tamale
Mr. McGoo is offline   Reply With Quote
Old 07-12-2006, 11:52 AM   #790
CCristo's Avatar
Trader Rating: 55 (100%+)
Rick,
Great job at the worlds.
Will the new packs have the equilize port on the bottom of the packs like the existing packs? It'd be nice to have the port on the top so I don't have to remove the pack from the car when charging with my scorpion charger.
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 07-12-2006, 11:54 AM   #791
Originally Posted by CCristo
Rick,
Thanks!
The balancing port is on the top.
Old 07-12-2006, 12:10 PM   #792
mobileracer24's Avatar
can someone tell me more about lipos. i would like to know if i can take the pack apart the plastic case and make a fore cell pack to run in my twelth scale and if so would i be able to just run two cells to be fair racing until my friends got the cells to run.thanks just trying to make my ride go faster!
mobileracer24 is offline   Reply With Quote
Old 07-12-2006, 01:20 PM   #793
bvoltz's Avatar
Trader Rating: 44 (100%+)
Sorry for asking a question that has been anwswered here, I just can seem to find the answer, and yes, I did use search....
What is the weight difference between a pack of 3600 and the LiPo?
bvoltz is offline   Reply With Quote
Old 07-12-2006, 01:25 PM   #794
bvoltz's Avatar
The simply answer is no, based on your described needs above. These packs are long and thin NOT fat and short (like me... LOL!!!).
Also by removing the case, you are reducing the protection factor that the case brings to the table and I'm pretty sure this would void the warranty, but someone from Orion would to verify that.
Bottom line - if you do this, will waste a good lipo.... so I would not recommend it.
Old 07-12-2006, 01:28 PM   #795
Rysuleod's Avatar
Info from tower's site.
Platinum lipo:Weight: 10oz (285g)
3600 - 6 cell stick pack: Weight: 14.5oz (410g)
Rysuleod is offline   Reply With Quote
ORION PLATINUM 4800 LIPO sedanracer8 R/C Items: For Sale/Trade 21 12-18-2007 08:09 PM
>>> Orion Platinum 4800 Lipo <<< rraden R/C Items: For Sale/Trade 9 10-22-2007 09:55 AM
Is the Mamba Max 7700 to much for the Platinum 4800 Lipo _pilot_ Electric On-Road 2 10-10-2007 01:52 PM
Team Orion Platinum Lipo Pack danjoy25 Australia For Sale/Trade 0 05-10-2006 04:26 PM
FS Orion Platinum Lipo!!! Glowster21 R/C Items: For Sale/Trade 20 04-05-2006 06:37 PM
