Old 05-19-2006, 11:54 AM   #661
Trader Rating: 38 (100%+)
Originally Posted by rampal
hi, I just get my first platinum... however, regarding cables & connectors, I get the tamiya connector with the cables but it is not soldered to the twisted gold connectors.... those last have threads inside and not solder tabs.... as I want to use it with the tamiya connector, is it enough to just "twist" the
gold connectors on the soldered end of the cables? If not, how do I solder the cables to the connectors? does not seem easy.... at least will be "messy"...
thanks,
The easiest way I have found it to put solder on the wire (enough to get a tight fit with the gold connector but not so much that you cant slide it on). Then put a little solder on the outside if the gold connector which will allow the connector to heat up enough to melt the solder on the wire and get a good bound. I usually then put some heatshrink around the connection. Hope that made sense.
If you are going to go through all that trouble though you might just want to solder the gold connectors to the wires on your ESC and bypass the tamiya connector. Guess it depends on what you are using on your charger and other batteries.
or8ital is offline   Reply With Quote
Old 05-19-2006, 02:06 PM   #662
rampal's Avatar
Send a message via MSN to rampal
yeah, that makes sense.... however, I have three different chassis & three esc's... and one use tamiya's connectors.... I guess I'll have to change all for deans... but the same problem arises.... how to get a good bond from that connectors.... I'll look around for some with proper soldering tabs....
thanks!
by the way, all of you get the battery with the tamiya not soldered to the gold connectors? I thought the intention was sort of "plug&play" not "if you don't have a 60w soldering gun go to a hardware store an buy one, solder nice, check correct bonding, wrap it nice on shrink wrap and then play"....
god d#$mit! I'm a mac guy, don't wanna mess with drivers or service packs....
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 05-19-2006, 02:30 PM   #663
NiMo's Avatar
Just checked my Tamiya lead, the gold connectors are soldered to the wires.
I only use this lead for battery charging.
NiMo is offline   Reply With Quote
Old 05-21-2006, 07:03 AM   #664
Just wondering how many tracks out there are allowing these packs to be run in mod or stock class? At my local track we allow them in mod only and there are about 7 or 8 guys running them. I'm on the verge of taking the plunge but waiting for some information on the new packs Rick was talking about in earlier posts.
Davenport is offline   Reply With Quote
Old 05-21-2006, 07:45 AM   #665
To late. I just took the plunge . I hope I dont regret buying the current battery vs. the soon to be released one. Anyone want a Reactor30, Tekin tray or some 3800s .
Old 05-21-2006, 11:08 AM   #666
just brought an orion battery what is the best way to mount it in a tc4 factory team any one got idea's or pictures?
beasley301 is offline   Reply With Quote
Old 05-21-2006, 11:29 AM   #667
how do you set up a much more charger to charge them ?
Old 05-23-2006, 03:46 PM   #668
LasagnaCat's Avatar
Trader Rating: 143 (100%+)
Send a message via AIM to LasagnaCat
Follow the instructions in the manual, find a good book, and wait about five hours for your pack to charge.
The Cell Master is great for nimh packs, not so hot for lipos due to the 1 amp charge limit.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 05-23-2006, 04:02 PM   #669
AdrianM's Avatar
The Orion Advantage Pro charges them in one hour. My IB3800's take 50min to charge at 6A. I have heard it is safe to charge the Platinums at up to 10A so you can fully charge them in just under 30min. Battery life might suffer a bit though.
Adrian Martinez
Old 05-23-2006, 04:35 PM   #670
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Been using mine for the last 2 weeks now. I have use both Duratrax Ice and Integy 16x8v6 with no probs. I normally charge until the chargers amp drops around less than 2 amps. and it never takes longer than 20 minutes as I tend to use it for at least 2 heats. I know I can probably make another heat but I need to justify bringing a charger
Fingers cross that the current model fits the new Tamiya Evo 5
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 05-25-2006, 11:27 PM   #671
kawada's Avatar
Pls advise whether Much More - Cell Master can charge Team Orion 4800 Lipo? If so, pls share the settings ? Thanks!
kawada is offline   Reply With Quote
Old 05-26-2006, 08:59 AM   #672
hi used my orion batteries last night indoors on carpet, topped up between runs car had alot more top speed and punch that 4200's i recomend use to anyone
Old 06-01-2006, 06:05 AM   #673
has anyone tried to charge the platinum lipo with bantam BC5 charger?
azmio is offline   Reply With Quote
Old 06-01-2006, 08:27 AM   #674
Rick Hohwart's Avatar
I am not familiar with that charger. But if it can charge a 2-cell 4800 mAh capacity LiPo battery at 1C (4.8A), it should charge it with no problems.
Rick Hohwart is offline   Reply With Quote
Old 06-01-2006, 10:05 AM   #675
LasagnaCat's Avatar
It can, but only at up to one amp. Two cells.. 1 amp charge rate.. about a four or five hour wait. (Still) not a good charger for lipos.
ORION PLATINUM 4800 LIPO sedanracer8 R/C Items: For Sale/Trade 21 12-18-2007 08:09 PM
>>> Orion Platinum 4800 Lipo <<< rraden R/C Items: For Sale/Trade 9 10-22-2007 09:55 AM
Is the Mamba Max 7700 to much for the Platinum 4800 Lipo _pilot_ Electric On-Road 2 10-10-2007 01:52 PM
Team Orion Platinum Lipo Pack danjoy25 Australia For Sale/Trade 0 05-10-2006 04:26 PM
FS Orion Platinum Lipo!!! Glowster21 R/C Items: For Sale/Trade 20 04-05-2006 06:37 PM
