Old 05-12-2006, 04:14 PM   #646
It is because they have Marc Reinhard - believe me he would beat anybody with a TC4
cvt01 is offline   Reply With Quote
Old 05-12-2006, 04:20 PM   #647
CarbonWorks's Avatar
Does the platinum hit the rear bulkhead in the T2? If so how much would the thing need to move forward to clear?
CarbonWorks is offline   Reply With Quote
Old 05-12-2006, 10:06 PM   #648
According to xray there is no other way to fit a lipo pack in the t2 but modifying the right rear bulkhead
Old 05-12-2006, 10:44 PM   #649
Maybe not with the stock chassis, but I bet I can make it work. I already make a chassis for the car, and I make a changeable battery tray system for other cars. I don't see why this system wont work for the t2 as well. Since I don't own a T2, I need a little more input from others. This is the tray system I use on the ZX-5. The chassis is milled out .070" to allow the batteries to sit as low as possible. You can run either the platinum lipo, or regular NiMH batteries just by changing trays.
Old 05-12-2006, 11:15 PM   #650
FAST1's Avatar
The T2 (X-ray) has a bulkhead that will have to be mill out in order for the Platinum to fit. No extra or carbon chassis will let this happen.
FAST1 is offline   Reply With Quote
Old 05-12-2006, 11:28 PM   #651
Why can't the battery be moved forward. The lipo is the same size as the regular pack, it just has a square corner. If the pack were moved forward, your saying it still wouldn't work?
Old 05-12-2006, 11:41 PM   #652
SpeedyPenguin's Avatar
Because the right rear bulkhead is formed so that the cells of a NiMH can slide under a section of bulkhead with the gap between cell, unlike LiPo
Slightly describing picture of way batttery is mounted
SpeedyPenguin is offline   Reply With Quote
Old 05-12-2006, 11:46 PM   #653
Ya , I got it. I went to their website and found a picture. Is that bulkhead substantial enough to remove that hump and still do its job?
Old 05-16-2006, 04:16 PM   #654
Is it safe to chage the TO platinum packs with a Great Planes Trition charger, if yes, What setting should be used?
vadn1 is offline   Reply With Quote
Old 05-16-2006, 04:29 PM   #655
AdrianM's Avatar
It is very safe to do this. However the Triton maxes out at 2.5A charge for Lipo so it takes 2 hours to charge the pack .
The settings are:
LiIo charge
7.4v 2.5A
Adrian Martinez
Old 05-17-2006, 12:49 PM   #656
Secret_weapon's Avatar
hi
I was planning to order from towerhobbies, unfortunately they say its flamable and cannot be shipped via air... Is there anyway i can get it ?
thanks
Secret_weapon is offline   Reply With Quote
Old 05-18-2006, 03:34 AM   #657
rampal's Avatar
Send a message via MSN to rampal
Originally Posted by Secret_weapon
hi
thanks
Had the same problem, but there are other places (and plenty!!). I've used hobbymania, check the Retail forum for them. They have competitive prices. I received it yesterday in Madrid, my hometown, but as I'm at London now, I can't play with it until weekend
You can also try RC Champ.... check the Retail Forum!!
cheers,
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 05-18-2006, 03:52 AM   #658
hobbipro's Avatar
Trader Rating: 21 (100%+)
Try www.stormerhobbies.com I had one overnighted.
hobbipro is offline   Reply With Quote
Old 05-18-2006, 08:15 AM   #659
I had one 2nd day air delivered from amain hobbies too.
Old 05-19-2006, 11:45 AM   #660
rampal's Avatar
hi, I just get my first platinum... however, regarding cables & connectors, I get the tamiya connector with the cables but it is not soldered to the twisted gold connectors.... those last have threads inside and not solder tabs.... as I want to use it with the tamiya connector, is it enough to just "twist" the
gold connectors on the soldered end of the cables? If not, how do I solder the cables to the connectors? does not seem easy.... at least will be "messy"...
thanks,
ORION PLATINUM 4800 LIPO sedanracer8 R/C Items: For Sale/Trade 21 12-18-2007 08:09 PM
>>> Orion Platinum 4800 Lipo <<< rraden R/C Items: For Sale/Trade 9 10-22-2007 09:55 AM
Is the Mamba Max 7700 to much for the Platinum 4800 Lipo _pilot_ Electric On-Road 2 10-10-2007 01:52 PM
Team Orion Platinum Lipo Pack danjoy25 Australia For Sale/Trade 0 05-10-2006 04:26 PM
FS Orion Platinum Lipo!!! Glowster21 R/C Items: For Sale/Trade 20 04-05-2006 06:37 PM
