Old 04-26-2006, 08:04 AM   #571
NiMo's Avatar
Originally Posted by andyuk99
So for the SLCC, we can use in practice
If the clubs allow them then yes you can use them in practice, but they are not race legal in any UK Nationals yet.
Also controlled practice (if used) may only give you a race length run.
NiMo is offline   Reply With Quote
Old 04-26-2006, 10:08 AM   #572
Many racers use them for practice and club races anyway !
Nicolas is offline   Reply With Quote
Old 04-26-2006, 11:55 AM   #573
bvoltz's Avatar
Trader Rating: 44 (100%+)
Can anyone tell me how to balance these LiPo pack on an ICE charger?
bvoltz is offline   Reply With Quote
Old 04-26-2006, 12:39 PM   #574
rs4rallydriver's Avatar
I don't know if you can balance them with the ICE. I read an advertisement that said: "tests have shown that balancing is not needed for the platinum li-po". of course, this goes against everything I have ever heard about li-po packs... so I really am not sure.
what I would like to know (in addition to the above inquiry about pack balancing) is has anyone tried charging one of these packs with an MRC Super Brain 977 pro series twin charger? that is what I have. and it has been perfect so far with my "regular" packs.
They say that it is designed to charge Ni-Cad, Ni-Mh, 12v lead-acid,
Li-Ion, and Li-Po (up to 3 cell). seeing as I wouldn't want to put myself in an unsure situation, I just want to know if anyone has used this charger for Li-Po. I know that it says it can and will, but I just want to know what other people think of it as a Li-Po charger.
rs4rallydriver is offline   Reply With Quote
Old 04-26-2006, 12:56 PM   #575
Rick Hohwart's Avatar
Team Orion recommends the Advantage, Duratrax ICE, Kokam , and FMA Scorpion (w/Platinum adapter).
We have received reports of problems with other charger brands.
Rick Hohwart is offline   Reply With Quote
Old 04-26-2006, 01:20 PM   #576
Really? what kind of "problems"? the "it would be better to use a different charger" problems, or "OMG! it's gonna BLOW!" problems?!
Old 04-26-2006, 01:47 PM   #577
NiMo's Avatar
I have the "Prolux Digi-Charge 104" charger/discharger
AC 230v (230/240v for UK)
DC 11v-18v
Does:
NiCd 1-10 cells
NiMh 1-10 cells
LiPo 1-4 cells
Lead Acid 2v 6v 12v
Charge rates 0.5A to 5.0A (max 4.0A for LiPo)
It charged the LiPo with the correct readings dropping slowly to 0.5A then cuts off once the 8.4v limit was reached.
Not yet got the F103GT built (got a cold bug) so I have not run the battery which was charged Friday last (took 1h45m from new).
Old 04-26-2006, 01:57 PM   #578
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
i have used my ICE for this
but i now use a prodigy II charger by ripmax cost £65.00 (uk)
5 amp max
doesnicd
nihm
li-po
li-ion
tell the charger 4800 capacity it charge`s @ 4.8 a till the volts start rising then adjust`s it self
you need not any fancy chargers for this baby
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 04-26-2006, 02:20 PM   #579
NiMo's Avatar
True
Mine also does the RX pack on the nitro car, and the NiMh packs in the starter box, all this for £90.
Old 04-26-2006, 02:40 PM   #580
newracer's Avatar
R/C Tech Charter Subscriber
To balance a lipo pack you need access to both leads on each cell in the pack. The Platinum has 4 cells, in 2S2P configuration. I am not sure if you can access all the leads.
newracer is offline   Reply With Quote
Old 04-26-2006, 05:20 PM   #581
bvoltz's Avatar
The LiPo has a port on the bottom side for "Balancing"... but is very small port.
Old 04-26-2006, 10:55 PM   #582
newracer's Avatar
Then if you have a connector to fit the port you should be able to balance it with any charger, one cell at a time.
Old 04-27-2006, 12:01 AM   #583
WheelNut's Avatar
Send a message via MSN to WheelNut
Or you could buy a balancer, thunder power sells one. You should be able to get a balancer at any shop that sells lots of planes/helis.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 04-27-2006, 12:49 AM   #584
You should get the Team Orion balancer and they also have the little balancing plugs on www.teamorion-avionics.com !
WorldCup2004 is offline   Reply With Quote
Old 04-27-2006, 10:52 AM   #585
I think the easiest way would be to balance them with the new Avionics charger using the 2mm balancing port.
ORION PLATINUM 4800 LIPO sedanracer8 R/C Items: For Sale/Trade 21 12-18-2007 08:09 PM
>>> Orion Platinum 4800 Lipo <<< rraden R/C Items: For Sale/Trade 9 10-22-2007 09:55 AM
Is the Mamba Max 7700 to much for the Platinum 4800 Lipo _pilot_ Electric On-Road 2 10-10-2007 01:52 PM
Team Orion Platinum Lipo Pack danjoy25 Australia For Sale/Trade 0 05-10-2006 04:26 PM
FS Orion Platinum Lipo!!! Glowster21 R/C Items: For Sale/Trade 20 04-05-2006 06:37 PM
