Old 04-25-2006, 01:53 PM   #556
Joel Lagace's Avatar
Is it simply a matter of just allowing them?
We have minimum chassis weight rules so the lipo users would have to lead up there cars to make weight.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 04-25-2006, 02:19 PM   #557
R40Victim's Avatar
We just allow them, because the only time we noticed a difference is near the end of a run, where all the Nimhs have started to fall off. They're actually slower the 1st minute or two...when the Nimh packs are all freshly charged and kickin out high voltage.
R40Victim is offline   Reply With Quote
Old 04-25-2006, 02:25 PM   #558
SO at full charge they are never above 7.4 volts because of there charge characteristics? LipOs dont get "peaked" before runs because they dont accept it correct? So for a 5minute race they would probably start off lower then nihm but hold a straighter voltage curve for the duration of the race?
Again without data from what your saying they may be on average the same as a nihm for a 5 minute duration? Start off lower end higher vs start off higher end lower...
ITs definatly intresting.
I wonder how the motorcross guys got 250 4-stroke to run with 125 2-stroke?
www.rcottawa.com
Old 04-25-2006, 02:56 PM   #559
Here is the picture from Car Action
Nicolas is offline   Reply With Quote
Old 04-25-2006, 03:07 PM   #560
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Yes
when the peak/orion pack is charging it is ticking over around 8.0+ volts it only goes up to 8.4 then stops & by then the pack is only taking 1.5a charge
nimh pack got out on track with around 8.8 volts (peaks of around 9.2 ) so really the c-cells are the ones that are using misreading peak volts umlike the li-po it stay`s @ 7.4 for the duration much longer
if peak redone the 7.4 to 7.2 to keep the munbers game right will it still be passed in the rule`s , i think not rule makers will come up with some thing to stop it being legal wrong colour,to big ,to simple,to easy to look after Blah Blah Blah
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 04-25-2006, 03:26 PM   #561
Rick Hohwart's Avatar
This is actually contrary to what I have found in my personal testing. But if it helps to make them legal, I accept it
Rick Hohwart is offline   Reply With Quote
Old 04-25-2006, 03:32 PM   #562
MR JOLLY's Avatar
aldershot club in UK allow peak li-po now (in 19t spec class only)
so that means i have 4 clubs i can use this grey box at
Old 04-25-2006, 03:35 PM   #563
Old 04-25-2006, 03:44 PM   #564
AdrianM's Avatar
LiPo's can feel soft early in a run because they don't really get hot during charging. Like all batteries the internal chemical reaction is more efficient at higher temperatures (to a point).
The high level airplane guys use heating pads on a low setting (what people with back injuries use) to pre-warm packs before flights in cold weather.
This same concept applies to NiMh cells during charging. If the cells are cold their IR's get high and voltage is poor. This is why charging packs on a fan is bad and why Much More Makes a Warming Tray for charging in cold weather.
Note I said pre-warm NOT pre-heat. The packs only need to be around 95degF to get the warming benefit
Adrian Martinez
Old 04-25-2006, 04:07 PM   #565
NiMo's Avatar
I pulled out all my hair getting this pushed through, now we just need the LiPo racers to show up.
They are also allowed in 2wd Electric class with 27t Stock, my F103GT nearing completion although this will only be the 2nd class car as my Nitro car is the main car.
NiMo is offline   Reply With Quote
Old 04-25-2006, 04:42 PM   #566
Default SLCC
So for the SLCC, we can use in practice
Andyg01 is offline   Reply With Quote
Old 04-25-2006, 05:41 PM   #567
kuzo's Avatar
Send a message via MSN to kuzo
Originally Posted by LasagnaCat
No issues running them that way? The battery instructions recommend not running the pack below 6 volts, while that cutoff takes it down to 5.3v per pack using the default setting.
No issues yet but not a lot of runs on it yet. They can be programmed using a multimeter and floowing the instructions. However according to the Orion faqs you can run the Platinum until your car starts to slow. This cuts off before I noticed any slowdown. I'm intending to play with the custom cutoff before any further runs. I now have two of my kid's cars running these and I'm not going to take any chances.
kuzo is offline   Reply With Quote
Old 04-25-2006, 06:54 PM   #568
Regional Moderator
Darkseid's Avatar
Just to pull everyone away from the 'fun' issue of legality and intergration for a second...
Did anybody else see the technology section of CNN today? While talking about the ever increasing gas prices, they did some coverage on a new line of Lithium powered cars. What does that have to do with this thread???
Well those cars were powered by Lithium batteries made by....who else.....Kokam. The same company that makes our packs for Orion/Peak.
Considering there are still people who think you can't even use these packs outside during the summer, hopefully a couple of them caught that little section on CNN. And maybe, just maybe the fact that these cells will soon be used in full sized cars will show people that they are more than safe enough to be used in our 1/10 cars.
TLR 22...Tamiya F104...
Old 04-25-2006, 07:12 PM   #569
R40Victim's Avatar
Glad somebody else saw it, I thought I was the only guy on the planaet who did...
Old 04-25-2006, 10:44 PM   #570
Tsquare's Avatar
I have been reading this thread for the last few weeks, IMHO the use of Lipo's vs. sub-c cells is a no brainer. The batteries are better, end of story. The idea that you could race all qualifers and mains with one battery pack and never have to worry about losing runtime or punch is amazing. In addition to that fact, no more discharging, equalizing, matching, IR, run-time, dealing with the fact tha my packs are 1.18 the guy I race against has 1.19, bla, bla, bla, bla, bla, bla. And yes I know from reading this thread that you do need to equalize Lipo's every so often, but it's minimal vs sub-c's. The point is I can spend more time on other things in life vs. caring for my battery packs. In addition, the cost savings of having a couple of Lipo packs at $280.00 vs 6 sub-c packs at $360.00 and not having to deal with the reality that as soon as I start using my sub-c batteries I will see a noticable drop off in performance almost immediatly. Lastly, because of the simplicity and lower cost of the use of Lipo's and the new low maintenance motors whether brushed or brushless, we could potentially see a growing popularity of our sport, and then maybe we would have more tracks and events to run on a consistent basis, IMHO.
Tsquare is offline   Reply With Quote
ORION PLATINUM 4800 LIPO sedanracer8 R/C Items: For Sale/Trade 21 12-18-2007 08:09 PM
>>> Orion Platinum 4800 Lipo <<< rraden R/C Items: For Sale/Trade 9 10-22-2007 09:55 AM
Is the Mamba Max 7700 to much for the Platinum 4800 Lipo _pilot_ Electric On-Road 2 10-10-2007 01:52 PM
Team Orion Platinum Lipo Pack danjoy25 Australia For Sale/Trade 0 05-10-2006 04:26 PM
FS Orion Platinum Lipo!!! Glowster21 R/C Items: For Sale/Trade 20 04-05-2006 06:37 PM
