Platinum Lipo
Old 04-19-2006, 10:36 AM
  #511
bvoltz's Avatar
Trader Rating: 44 (100%+)
What you can do is make your wire leads, one with the end that will go into the pack, then Deans on the other end, make enough for all the packs you have, and spare, just in case... When you get to the track and you not in a rush, put the ends into your LiPo pack, then your set until it is time to leave, then remove the wire leads... you can not put Deans together wrong... and then Deans on the other end of the wire for speedo, this is how my setup is. But I currently only have one pack. I'm sure I will take some crap from the other club races, because they see LiPo's as pack that is faster then they have. Not because of the risk, (they view the risk as the same as any other batteries, this is good thing... Now just to get ROAR to make them approved).
bvoltz is offline
Old 04-19-2006, 11:09 AM
  #512
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
i`m taking crap allready through jealousy i reckon
MR JOLLY is offline
Old 04-19-2006, 02:05 PM
  #513
bvoltz's Avatar
It would be nice if ROAR would make this legal, one option is just for Mod, for one year to see how it works out. I still think they should make the legal and get on with it.
I have always viewed MOD as a class that every thing is fair, including lovin and war, and MOD is war. The best of the best, tech nothing, but the car weight and size, let them run I say...
bvoltz is offline
Old 04-19-2006, 03:41 PM
  #514
Rick Hohwart's Avatar
The fact is that most tracks do not use full blow ROAR rules in the first place. The only place they apply is at some of the bigger national races.
Look at batteries. How many tracks actually turn away those using IB4200 and GP4300 packs? Most if not all the big non-sanctioned races allow them. So if tracks are going to ignore ROAR rules regarding batteries, it only makes sense that they should allow LiPos as well.
Either enforce the rules, or don't.
Rick Hohwart is offline
Old 04-19-2006, 03:44 PM
  #515
Regional Moderator
Darkseid's Avatar
Originally Posted by MR JOLLY
this is why i say only experience racers use these li-po`s
Adrian i can see he`s point though
if you connect up the pack the wrong way the speedo up in smoke would be the least of he`s worry`s , the whole car will go
you don`t get a second chance with these li-po`s , you do with c-cells odd spark then it slowly (compared to li-po) get`s fizzing, li-po`s will go `BANG` ,so much more power in them li-po`s
When I first got mine, I was so careful with it, it was ridiculous. It was like a first time parent with their new child. Then a few weeks ago, in a moment of inattention, I did hook mine up backwards. I had the positive already hooked into the negative, then as I went to put the negative into the positive, I got a quick spark! I instantly pulled the plugs away, hooked them up correctly, and went on with life.
Needless to say, I'm back to "first time parent mode" permanently!
But I guess the battery will give you a 2nd chance. Well, at least if you catch it when you first hook it up wrong and before the power is turned on.
Darkseid is offline
Old 04-19-2006, 03:48 PM
  #516
Regional Moderator
Darkseid's Avatar
THANK YOU!!!
Darkseid is offline
Old 04-19-2006, 04:04 PM
  #517
danjoy25's Avatar
Trader Rating: 37 (100%+)
Anyone knows which shop sells them the cheapest and that can send overseas?
danjoy25 is offline
Old 04-19-2006, 06:16 PM
  #518
bvoltz's Avatar
I'm not sure about overseas, but cheap... http://www2.towerhobbies.com/cgi-bin...1&I=LXLXR6&P=K
Then enter the discount code to match the amount you spend... http://www.towerhobbies.com/index.html
bvoltz is offline
Old 04-19-2006, 06:17 PM
  #519
bvoltz's Avatar
I agree...
bvoltz is offline
Old 04-19-2006, 06:29 PM
  #520
danjoy25's Avatar
Its says they can't post them via air.
danjoy25 is offline
Old 04-19-2006, 08:32 PM
  #521
bvoltz's Avatar
Where do you live?
bvoltz is offline
Old 04-19-2006, 11:48 PM
  #522
MR JOLLY's Avatar
we don`t have this thinking over here ,nearly all `MAIN` tracks won`t let you use them even when club racing
most of it to do with `health & saftey` band wagon through the BRCA
only the small club`s will let you ,but that`s pushing it a bit ,lot`s of finger pointing & bitching over here if some one has some thing new
MR JOLLY is offline
Old 04-20-2006, 12:12 AM
  #523
rampal's Avatar
Hey danjoy, if you finally manage to make tower ship them overseas, let me know.... here in Spain they cost half of the kidney.... and as I want two, a whoooole one.....
rampal is offline
Old 04-20-2006, 03:37 AM
  #524
Stein Tumert's Avatar
Stormer Hobbies
http://stormerhobbies.com/
Stein Tumert is offline
Old 04-20-2006, 07:07 AM
  #525
I love the fact that in Europe and Asia, the rules (in general) are pretty consistent all the way across the boars and that national rules are used at all levels.
We used to try to push that feeling here in the U.S., but most tracks do not want to take the time to do tech inspections or run a professional race program on the club level.
