Old 02-28-2006, 07:06 PM   #376
kawada's Avatar
Originally Posted by or8ital
It comes partial charged. It was the difference between 4800 and what the charge left on it was.
wow... that means it required 59mins to top off this Lipo .... Since it spent me that much .... is it normal then ??
Thx in advance
kawada is offline   Reply With Quote
Old 02-28-2006, 07:11 PM   #377
Trader Rating: 38 (100%+)
It does take quite a while to charge. Esp the second part of the charge. At least it does for me on my ICE.
or8ital is offline   Reply With Quote
Old 02-28-2006, 07:39 PM   #378
kawada's Avatar
Sorry Pal .. how about re-charge after 5 or 10 mins race ?? how long u had experienced with ur ICE to peak ur Lipo ..
Old 02-28-2006, 07:42 PM   #379
Well it usually takes about an hour (just guessing never timed it) after about 25 min of using it. So based on that I would guess about 10-20 min.
Old 02-28-2006, 07:59 PM   #380
kawada's Avatar
Trillion thx for the valuable info ..
Old 03-01-2006, 03:53 AM   #381
I heard that they make 19 minutes with a JMRCA 23 turn motor ! And that the standard racing will be 15 minutes !
WorldCup2004 is offline   Reply With Quote
Old 03-01-2006, 04:10 AM   #382
Default weight
not the best way, but I wanted to keep the overal weight correct
Andyg01 is offline   Reply With Quote
Old 03-01-2006, 12:29 PM   #383
How much weight is that ?
Nicolas is offline   Reply With Quote
Old 03-01-2006, 12:39 PM   #384
I would guess 112g which is the weight difference between the lipo and 6 IB3800 cells. Im thinking of doing the same thing though Im going to put the weights either on the inside (since I have my battery a little to the outside) or spread them out. I assume all on one side isnt as close to a real battery as you can get. A real battery would be equal on both sides and sit a little lower on the chassis (I have plastic on the bottom of mine that goes in the battery slots).
Old 03-01-2006, 01:37 PM   #385
big ones 10g small 5g
I did have weights either side of the battery, but the inside weights ran very close to the belt.
Also the two end weights butt upto the battery posts, so there is no chance of the pack moving inwards.
Old 03-01-2006, 01:41 PM   #386
95grams of lead
total weight of lipo 361g
A GP3300 = approx 387g
My car was always over weight
Old 03-03-2006, 03:45 AM   #387
kawada's Avatar
Now here is the weight comparison with 3300 & 4200 .. dont get any 3700 so ...
Old 03-03-2006, 03:47 PM   #388
very very light batteries, and so much power !
Old 03-05-2006, 09:27 AM   #389
Who has already raced the Platinum Lipo and how was it ?
Old 03-06-2006, 04:07 PM   #390
Regional Moderator
Darkseid's Avatar
I've already raced mine in 19T class on carpet. It was very, very impressive. As was mentioned here before, how much of a increase in speed and punch you see will depend on how good your regular packs are.
What I mean is, if you use $70-$80 packs with 1.2+ volts, then the Platinum will likely feel about the same with a slight boost from the weight loss.
If however, you use $45-$55 middle of the road packs with around 1.19v, then you will notice quite a difference in speed and punch.
And of course, theres the comfort of knowing you'll end the race at the same speed you started it at, and you'll never dump...
TLR 22...Tamiya F104...
ORION PLATINUM 4800 LIPO sedanracer8 R/C Items: For Sale/Trade 21 12-18-2007 08:09 PM
>>> Orion Platinum 4800 Lipo <<< rraden R/C Items: For Sale/Trade 9 10-22-2007 09:55 AM
Is the Mamba Max 7700 to much for the Platinum 4800 Lipo _pilot_ Electric On-Road 2 10-10-2007 01:52 PM
Team Orion Platinum Lipo Pack danjoy25 Australia For Sale/Trade 0 05-10-2006 04:26 PM
FS Orion Platinum Lipo!!! Glowster21 R/C Items: For Sale/Trade 20 04-05-2006 06:37 PM
