Old 12-23-2005, 01:39 AM   #1
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Default What foam tires is everyone running
I run on grey ozite carpet in stock sedan. What tire choices is everyone running?
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 12-23-2005, 02:21 AM   #2
Bazzer's Avatar
Send a message via MSN to Bazzer
I use the new two stage tires from Jaco and my car feels like its on rails. However if you don't want to spend the extra bucks on the new tire the I would suggest the Purple/orange jacos up front and Purple Jacos for the back. I have used these tire combos for the past two years and I haven't found anything better yet. The last tire combo works great and wears even better. Hope this helps.
Bazzer
Bazzer is offline   Reply With Quote
Old 12-23-2005, 05:46 AM   #3
Send a message via AIM to R/C Anonymous
ive always ran double pink, double pink/orange: cyan and magenta
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 12-23-2005, 05:50 AM   #4
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
Jaco Double Pink / Orange Front - Jaco Double Pink Rear - either single or 2 stage.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 12-23-2005, 06:03 AM   #5
offroader's Avatar
Trader Rating: 15 (100%+)
can anyone please advice what width foam tires is ideal for electric touring? Wider gives more traction and less wear? so why isnt anyone running 30 mm width apart from the tires scraping on the suspension?
offroader is offline   Reply With Quote
Old 12-23-2005, 06:36 AM   #6
MAD916's Avatar
I beleive 28mm is the standard for 10th Scale Electric...30mm is for 190mm and 235mm 10th nitro??? That's what I believe is correct. We run GQ foams on the trademark "unbreakable orange rims"........
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 12-23-2005, 06:25 PM   #7
offroader's Avatar
i think its 24mm for rubber electric, but there is no standard for foam electric as you can jsut get the nitro tires (30mm) and cut it down. But i dont know what the effect will be if i run 30mm or 26 mm. Will it be more sluggish because of the bigger wheels? But it will give more grip...
Old 12-23-2005, 08:10 PM   #8
i am using parma foams, plaid up front and magenta in rear
Fantomcat is offline   Reply With Quote
Old 12-23-2005, 08:15 PM   #9
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Not many people mention these but I have had great success with the TRC magenta and cyan. I hit a bunch of stuff and for me the jacos are fragile while the TRC's dont break as easily.
Old 12-24-2005, 12:57 AM   #10
darnold's Avatar
T.M. tires are great also...pretty much the same coding system as TRC check them out at: www.tm-rc-racingcomponents.com
darnold is offline   Reply With Quote
Old 12-24-2005, 02:48 AM   #11
PitCrew's Avatar
All they guys at my track are running black foam tires...
PitCrew is offline   Reply With Quote
Old 12-24-2005, 06:54 AM   #12
Trader Rating: 14 (100%+)
I'll second this one - TRC makes good tires. But I have been running the Jaco dbl pink/orange up front and dbl pinks rear cut down to 2.27". They are a bit cheaper than the TRC's and Parma's. I haven't tried the 2 stages yet, I don't think anyone at my local track has tried them yet either. I would just stick with something that works before trying something new.
o.s. power is offline   Reply With Quote
Old 12-24-2005, 07:44 AM   #13
TRC does make a good tire, but they are more expensive than the Jaco single stage tires. It will be interesting to see how good the new Trinity / TRC wraps are when they become available. I personally think the Jaco 2 Stage is the best tire on the market, but if you don't think you will notice the extra two tenth's, the Jaco single stage work just fine.
Anyone looking for a good deal on Jaco, check out this thread - http://www.rctech.net/forum/showthread.php?t=90458
Retired from RC....
Anyone remember running foam tires for off-road? Buckyaga Electric Off-Road 10 07-31-2008 03:45 PM
foam fk05 chasis and foam tires. Branden Moody R/C Items: For Sale/Trade 34 10-09-2007 12:20 AM
Running GRP tires on a CRT HookaMega Nitro Off-Road 7 10-01-2007 12:28 PM
What type of foam material are foam tires made from? pirate Electric On-Road 2 04-20-2007 09:40 PM
Jaco Foam Tires & Fast Tires Foam, Brand new. MugenMTX3Kid R/C Items: For Sale/Trade 11 01-03-2004 01:53 PM
