Old 12-23-2005, 01:19 AM   #1
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Default Jaco Plaid/Purples or Parma Plaid/Purples
Hey, does anyone notice a different in Jaco Plaid/Purples or Parma Plaid/Purples? is there any big difference? does one chunk less more then the other? give me some input
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 12-23-2005, 05:53 AM   #2
stiltskin's Avatar
Trader Rating: 102 (100%+)
A bunch of the local guys said that the Jacos were faster. I tried them and didn't see a difference. They don't chunk any more/less than the Parmas and (around here) they are $2 cheaper. I do like the new two-stage tires, though. Much smoother and the car definitely turns faster lap times.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 12-23-2005, 07:10 AM   #3
koabich's Avatar
Send a message via Yahoo to koabich
I am not sure on the performasnce difference as I have never run Parma but Jaco's wheels have a larger inside diameter so they fit some cars better. Jaco tires are also about 1.5mm wider. I have heard the rim on Jaco's is stronger as well.
koabich is offline   Reply With Quote
Old 12-23-2005, 07:34 AM   #4
rayhuang's Avatar
Parma tires in general are thought of as having more steering. Both in the Cyan/Magenta and Plaid/purple. This is partially due to rim stiffness and width of the orange strip on the combo fronts and of course they use foam from different suppliers.
A tip that applies to btoh or all brands of foam tires that I have learned is I dont really runs tires bigger than I want and let them wear down. If 2.25 is the optimal size I want-then I cut to 2.27.
My reasoning is that by running any foam tire from 2.35 down to 2.25, after so many applications of tire sauce and constant side loading (and hitting boards) all tires will start to peel away the edge or wear away the orange strip by the time you get to your optimal size. I have found (Jack Rimer told me this years ago) that a foam tire wears a lot when its out of its optimal size for your car. Think of it as a sweet spot. SO lets say its 2.25 again, tires may wear a lot from 2.35 to 2.27, but then wear seems to slow from 2.26 to 2.22 and then they wear out quick again from 2.22 to 2.10......... I run foams 12 months a yer and i am convinced this is true. I now cut my brand new tires down to 2.20!!!!
FS: SIX Pair JACO plaid NEW IN BOX $50 shipped MManson R/C Items: For Sale/Trade 0 08-06-2007 05:46 PM
parma plaid sets Jim S R/C Items: For Sale/Trade 5 06-15-2007 02:25 PM
1/12 Parma tires purples/magentas/greys/pinks BBSpence R/C Items: For Sale/Trade 13 12-06-2006 01:28 PM
JACO Plaid Tires NEW F/S!! jaysimpson R/C Items: For Sale/Trade 2 03-31-2005 06:06 PM
Looking to trade for Jaco plaid and purples. ZER01 R/C Items: Wanted to Buy 0 11-22-2003 06:45 PM
