Old 12-23-2005, 06:25 PM   #16
anthony390's Avatar
Send a message via AIM to anthony390
WOW guys thanks so much
ill keep those tips memorized
THANKS again youve all been helpfull
anthony390 is offline   Reply With Quote
Old 12-23-2005, 06:56 PM   #17
offroader's Avatar
Trader Rating: 15 (100%+)
to increase throttle response, top end speed and more run time , how about considering shaft?
offroader is offline   Reply With Quote
Old 12-23-2005, 08:48 PM   #18
anthony390's Avatar
TC3.5 (look down at my sig.)
Old 12-23-2005, 09:20 PM   #19
AdrianM's Avatar
Too bad shafts only give you one of the 3 things you mentioned
Honestly guys....with the current crop of cars. All you need to do is build and race. All the work has been done in the R&D office before the cars were released. Front belts should last at least a year of hard running. Rear belts should be replaced 2x per year if you run every weekend. 3x per year if you run mod.
FYI, WD40 increases belt drag by softening the rubber and making it sticky. Leave the belts dry. This was old tech that didn't pan out.
Clipping teeth makes the car smooth in the bench but increases tooth loading and does nothing on power except cause skipping and cause excessive belt wear.
Adrian Martinez
belt maintenence tips Ashley Cobb Electric On-Road 8 12-16-2007 09:41 PM
IB charging methods. That0neguy Electric Off-Road 1 04-13-2006 08:10 AM
540 Run-in Methods tc3=speed Australian Racing 34 09-25-2004 05:51 AM
Scoring methods rc_square24 Electric On-Road 2 02-03-2004 10:33 AM
Battery Charging Methods TS4N Australian Racing 5 03-07-2002 02:45 PM
