Old 12-21-2005, 09:43 PM   #1
nitrothugg's Avatar
Parallel battery pack question from a nitro guy (dont know nothin')
i'm working on an rc project and was wondering what the outcome would be if you were to wire 2 packs in parallel that had a different amount of cells?
for example, a 6 cell pack parallel to a 5 cell pack. i know the amp hour goes up when you join them in parallel with the same number of cells.
someone warn me before i blow myself up
nitrothugg is offline   Reply With Quote
Old 12-21-2005, 11:26 PM   #2
Hi,
Here's the science...
When you sodler cells in parallel,you add up the capacity but Voltage remains the same. When you solder in series then you add the voltage but cpacity is the same...
Hope this helps.
Ben.C is offline   Reply With Quote
Old 12-22-2005, 04:07 AM   #3
yeah u can do that. i know a guy who wierd two 5 cell reciver packs to get more run time.
even though voltage remains the same... an added benifit is you get a bit more punch from your servos coz the voltage drop is not as great when using the servos.
XingXing is offline   Reply With Quote
Old 12-22-2005, 04:49 AM   #4
Lokanas's Avatar
Do not do this. Basically it's the same as connecting the battery (5c) to the source with higher voltage (6c). It would cause current flowing from 6c pack to 5c pack (something like charging). Those packs won't work together like that.
You may only try playing with 2x5c packs - this would increase overall capacity if connected in parallel, but cells should be equally charged or discharged before connecting everything together.
Lokanas is offline   Reply With Quote
question about LI-PO BATTERY PACK FOR SANWA M8, 750MAH, 3S1P, 11.1V charging plug will g Radio and Electronics 2 05-02-2008 07:38 PM
Yet another battery pack question cargo Rookie Zone 4 02-03-2008 08:16 PM
Probably a silly battery question, lets say a 4300 Nimh pack was just one big cell.. Mabuchi540 Electric On-Road 9 03-02-2007 11:05 AM
From the quick question department: 4 cell battery pack wiring.... Mabuchi540 Electric On-Road 4 06-17-2005 10:09 AM
Question on Parallel Import 1/1 Car. kkyeo Singapore R/C Racers 12 05-13-2005 04:16 AM
