Build Complete: Tamiya DF-03Ra >
Like Tree9Likes
Old 11-24-2017, 05:53 PM
  #16
fyrstormer's Avatar
Fixed all pictures in this thread.
fyrstormer is offline
Old 11-26-2017, 01:11 AM
  #17
wtcc's Avatar
You are crazy!
I love it
fyrstormer likes this.
wtcc is offline
Old 11-27-2017, 01:09 AM
  #18
fyrstormer's Avatar
I am? What did I do this time?
Old 11-27-2017, 02:41 AM
  #19
wtcc's Avatar
In a positive way
By making this kit desirable with its blue bling bling and performance upgrades.
wtcc is offline
Old 12-17-2017, 06:19 PM
  #20
sum guy's Avatar
How the heck are you breaking ceramic bearings with just a brushed motor?
sum guy is offline
Old 12-17-2017, 07:39 PM
  #21
This car is awesome!
InfamousRacerX is offline
Old 12-18-2017, 12:13 AM
  #22
fyrstormer's Avatar
The bearing socket in the motor was crooked, and it was causing the bearing to bind-up just enough to make it wear out too fast.
Old 06-16-2018, 11:35 PM
  #23
fyrstormer's Avatar
Today, on an all-new episode of Fyrstormer Mods A Car That Nobody Cares About Anymore, I fitted a front swaybar to my DF-03Ra.
I geared it up just for fun, and quickly discovered that the taller-than-stock suspension was not up to the task of keeping the car going in a straight line. It's always had a tendency to wander a bit, but after gearing it up, it wandered so much during a quick test drive that I was seriously concerned it would crash into a curb before I could bring it to a stop. In addition, this car has always been a little too easy to powerslide, requiring immediate countersteering as soon as the rear breaks free or else the car would just spin-out on the spot. So, a front swaybar seemed like a good way to kill two problems with one stone.
The swaybar I fitted is a XV-01 medium swaybar, with the arms bent to a slightly sharper angle and trimmed about 4mm shorter. I also drilled a couple holes into the front swaybar mount so I could install set-screws, because for some reason Tamiya didn't include that themselves. Everything else was just stock XV-01 parts.
It drives much better now. It still powerslides easily, but all I have to do to rein-in the slide is let the steering return to neutral. And it goes in a straight line much more reliably now, too.
