Old 11-11-2002, 04:43 PM   #1
Default Super Glue for Tires
Hi guys,
got a newbie kinda question...
just wondering what do you use to glue the tyres to the rims?
Can i just use superglue or will that melt the rubber?
Thanks.
taybelZ is offline   Reply With Quote
Old 11-11-2002, 06:24 PM   #2
CRASH's Avatar
Trader Rating: 26 (100%+)
Team Losi TreadLock works really well. There are several companies that make glue for tires.
CRASH is offline   Reply With Quote
Old 11-11-2002, 06:39 PM   #3
Im2lazy's Avatar
just make sure its an rc car manufacturer that produces the CA glue, cheap imitations are cheap for a reason...
Im2lazy is offline   Reply With Quote
Old 11-11-2002, 07:12 PM   #4
alright thanks guys.
so you cant use the multi-purpose "super glue"?
needs to be a r/c manafactured brand of glue?
Old 11-11-2002, 07:17 PM   #5
popsracer's Avatar
Default Tire glue
I used "Zap" brand CA for a couple of years and would occasionally have a tire come unglued.
I now use "Team Kinwald" thin for my TC tires and have had no problems at all.
It is important that you clean the rims and tires where they contact to remove any molding residue. Motor spray works best but soap & water will do.
If you have a Dremel tool, you can scuff the rim with a fiber brush and clean up the tire bead with a sanding drum. This really makes for a fool proof bond.
popsracer is offline   Reply With Quote
Old 11-11-2002, 09:15 PM   #6
Iso Octane's Avatar
Default Re: Tire glue
I use Zap, and I have melted 8 rims and destroyed 8 tires trying to get the stuff unstuck.
Iso Octane is offline   Reply With Quote
Old 11-11-2002, 09:23 PM   #7
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
Losi glue. Just look on the pit tables at a National event. Everyone uses it.
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 11-11-2002, 09:32 PM   #8
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
I like the pro-line glue. The Losi stuff works fine, but since the pro-line is thinner, it is much easier to apply for me, and it seems to hold just as well.
Speedo is offline   Reply With Quote
Old 11-11-2002, 10:30 PM   #9
i assume your refering to the Team Losi TreadLock stuff?
Old 11-11-2002, 11:11 PM   #10
Correct.
BTW, Losi released a thinner formula a few months ago - red label.
Blue label is still the standard viscosity.
Tim Davis
Old 11-12-2002, 12:32 AM   #11
Send a message via AIM to ZER01
Plasti-Zap(CA++), don't ask me what the ++'s are for. It only comes in one viscosity-medium but it's thinner than their regular medium CA. This stuff won't fog the tire white as much as their regular CA and holds good if not better.
ZER01 is offline   Reply With Quote
Old 11-12-2002, 01:15 AM   #12
Im2lazy's Avatar
Pro line and losi work great. I don't trust Zap as much. We have a local brand that works better than zap. I kind of like the slightly thicker stuff, a little less brittle.
Old 11-12-2002, 03:01 AM   #13
rough512's Avatar
I used regular Loctite super glue on my Yokomo rims with sorex 36 tires...
looks fine so far...
Anybody tried rubber cement yet?
rough512 is offline   Reply With Quote
Old 11-12-2002, 03:11 AM   #14
Im2lazy's Avatar
I've seen people use similar things. They are more along the lines of shoe goo. The official name for the stuff was goop II.
seriously, that was the brand name...
It worked well, he swears by the stuff. He also uses it to glue the inserts to the rim if you like it that way. And he also uses it in every way I have used shoe goo in my life, so it is pretty much the same stuff.
Its weird but it seems to work.
whatever.
Old 11-12-2002, 05:07 AM   #15
Im pretty sure Losi stuff is made by Loctite, identical bottle, and works just as sensational as the Loctite stuff.
I will never go back to using anyother type of glue again.
Beware stay well away from the orion stuff it is useless
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
tires n glue tooyhycriters Nitro Off-Road 7 01-26-2008 03:05 PM
CA or super glue or what ever you call it, which is your favourite and why? aus jd 2703 Australian Racing 10 06-15-2006 11:51 PM
Can I use ELMERS glue to glue my tires to the rims? Jhyten Electric Off-Road 20 02-25-2006 11:49 AM
super glue removal Johnnytc3 Electric On-Road 4 06-25-2003 03:40 AM
Duct Tape, Super Glue and WD-40 TSR6 Chat Lounge 36 07-11-2002 04:04 PM
