Old 08-05-2006, 02:23 PM   #61
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Hi RLS
Hey thanks for the advice. I am working with my LHS to get the G3 parts ordered. I think I will go to the aluminum Front Beam to replace the GRP one I broke. Corally USA told me that the Aluminum Front Beam will work with the G3 chassis.
I just got the car from my friend who runs the SP12M and has the aluminum Wishbones. I ran it once Wed night then broke so I had to finish the heats with my Hara 12th scaler. I do think the G3 was real smooth even with center shock installed. I need to be creative and make a antenna mount ball stud taller for the shock so I clear the battery bracket.
Are you looking to sell any G3 parts? Are you in the US?
rinkrat99 is offline   Reply With Quote
Old 08-05-2006, 04:28 PM   #62
Grenade10's Avatar
Trader Rating: 37 (100%+)
Hey RinkRat - once you get my old car set up and working, I'll want it back!!
It will be fun to run on the carpet again this fall. Let me know when you want to set up a motor night and dyno and check your springs.
Now all I have to do is to get you using Pro-Trak chargers and we can always swap stuff!!
Let me know if I can help!
By the way, my 12M Euro is great on the outside asphalt track. For me the graphite T-plate works the best. Yes, I know this should not be the best, it just works with my set up and driving style.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 08-05-2006, 09:04 PM   #63
rinkrat99's Avatar
RLS
Do you have the G3 manual?
Can you send a copy?
Old 08-05-2006, 09:09 PM   #64
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
whats the grp means?.. i saw one on ebay it sells for 99$ it sats sp12m grp. just wanna know.
thanx
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 08-05-2006, 09:14 PM   #65
SMcpot's Avatar
Trader Rating: 22 (100%+)
thanx
Graphite reinforced plastic.....or fiberglass
SMcpot is offline   Reply With Quote
Old 08-05-2006, 09:23 PM   #66
pinggoy's Avatar
thanx..any advice for good 12 scale for asphalt racing?
TAMIYA TRF416X
Old 08-07-2006, 03:13 AM   #67
heavy's Avatar
Trader Rating: 20 (100%+)
Anyone know if it's possible to get a conversion of any sort to allow US style wheels on the rear of a Corally Sp12M ?
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 08-07-2006, 10:07 PM   #68
rinkrat99's Avatar
Hey RLS
I think I have a problem!
I compared the G3 chassis I have to a SP12M GRP version and my FrontBeam does not match up with the hole pattern of the 12M!
I am thinking the Aluminum Frontbeam will not work here!
See pics below
Corally SP12M-g3-vs-sp12m-closeup.jpg   Corally SP12M-g3-front-beam.jpg   Corally SP12M-frontbeam.jpg
Old 08-07-2006, 11:22 PM   #69
RLS
RLS's Avatar
Rinkrat99,
As I mentioned before, the G3 front end is different than the 12M's design. Parts are not going to interchange without alot of modification. The G3 aluminum front beam however would be a direct fit. My suggestion....replace what you have to with stock parts, I would use the G3 Graphite front beam and be sure to run a camber bar and have fun racing
, (while saving for the new Corally SP12XWE which hopefully will be released soon!)
To answer your previous question, sorry but no I don't have any G3 manuals left or I would be happy to send you a copy.
RLS is offline   Reply With Quote
Old 08-07-2006, 11:44 PM   #70
RLS
RLS's Avatar
In a word....no. For a time there was some metal size-reducing sleeve washers that you pressed into the rear bearings to allow the use of Associated-type rear axles but they weren't very popular.
Rinkrat99,
If you are serious about running the G3 for awhile, and you already ordered the 12M aluminum front beam but don't want it, PM me and maybe we can work out a parts swap to keep you going.
Old 08-08-2006, 04:25 AM   #71
heavy's Avatar
Thanks.
1/12th is just starting a revival here in Brisbane Australia and I am just getting into it after not having raced 1/12th since the 1980's. I have a SP12M and was thinking I would fit a standard servo but I think I need a smaller one - any ideas. Would a Futaba S3002 fit ok ?
Old 08-08-2006, 07:41 AM   #72
rinkrat99's Avatar
Hi RLS
I have not ordered any parts yet. I have three options now.
1) Use the aluminum G3 Front Beam $15 at Stormer Hobbies
2) Use the Graphite Front Beam $15 at Stormer
3) CAD the existing frontbeam and have a local guy do an aluminum or graphite version maybe strengthen the steering block mounts.
Thanks for the advice.
BTW - I also run the Hara and Quad12, the Q12 creator is a local guy here and may do the machining of parts for me
Old 08-08-2006, 08:23 AM   #73
TC Guy's Avatar
Does anyone know the Shore ratings for the 1/12 Corally tires? Or what tires does everyone run on mid and high bite carpet?
Thanks.
TC Guy is offline   Reply With Quote
Old 08-08-2006, 08:47 AM   #74
mooony's Avatar
Thanks.
I have the shore in excel file so if you want it send me a pm.
1402 Green tyres rear 1-12 28
1405 Orange (Outdoor Compound) rear 1-12 28
1406 Gold tyres rear 1-12 28
1407 Silver tyres rear 1-12 30
1408 Pink tyres rear 1-12 30
1412 Green tyres front 1-12 32
1416 Gold tyres front 1-12 36
1417 Silver tyres front 1-12 38
1418 Goldstar tyres front 1-12 30
1419 Silverstar tyres front 1-12 34
Ronald
mooony is offline   Reply With Quote
Old 08-08-2006, 08:54 AM   #75
TC Guy's Avatar
Didn't find it, I clicked on the 1/12th info, all it sends me to is info on the Sp12X.
sp12m corally nib papadocks R/C Items: For Sale/Trade 0 01-01-2008 04:37 PM
Corally 1/12 sp12m X 2 evo1 Australia For Sale/Trade 9 07-22-2007 05:48 PM
corally sp12m grp papadocks Electric On-Road 2 10-02-2006 08:37 PM
CORALLY SP12M Swampracer R/C Items: For Sale/Trade 11 01-15-2006 06:01 PM
Corally SP12M IMPACTPLAYR Electric On-Road 5 06-28-2003 04:06 PM
