Old 11-12-2002, 12:54 AM   #16
Send a message via AIM to ZER01
24mm Schumacher wheels weigh a ton! Them are the heaviest set of wheels I have ever own. They are nice and sturdy though.
Anyone know if Cross's 24mm dish wheel is more stiffer than their 12 spoke or are they the same?
jwwu, I would opt for either RPM's, Schumacher's or Yokomo's if your constantly hitting boards. These wheels will not break, crack or warp on you as much as others. Another good wheel out there is the old 26mm Losi, much like Schumacher but alot lighter. If their new 24mm is the same material, that's gonna be a nice wheel. If you are bad about hitting the boards DONOT buy Orion's "soft" or "hards", Pro-lines, Cross's 12 spoke or Sorex's.
ZER01 is offline   Reply With Quote
Old 11-12-2002, 01:12 AM   #17
Im2lazy's Avatar
I have to agree with proud winner.
One thing I'm sure of is that the absolute worst rims you could ever find is the OFNA ones... Many horror stories. Even I tried some (no Idea why ) At least they were junk tires.
I can run Yoks into the wall and they won't crack or warp. Some guy nailed me at about 45-50 (race nitro) at the end of the straight and my yok's were one of the okay things I had left. Still use them... I only use them b/c they are cheap and very stiff and the most durable.
the prolines don't warp as easily as HPI's and they never break.
Kyoshos feel just like Yokomo's, but they haven't seen as much action.
Im2lazy is offline   Reply With Quote
Old 11-12-2002, 01:18 AM   #18
Yeah OFNA's are worst than junk, I can't beleive someone would even make such a wheel, them new Endless wheels look to be the same material as the OFNA clears so I would be cautious of those also.
Old 11-12-2002, 03:19 AM   #19
Im2lazy's Avatar
cautious? stay clear at all costs!
I've heard 3 stories and they were 3 nightmares. If anything resembles them in anyway, I make sure put it on the highest shelf that I can reach so no poor soul has the trouble of purchasing them... they plain suck, and anything that looks anything like them sucks b/c the manufacturers were stupid enough to make them look like the OFNAs. that is how bad these are.
Onto good wheels....
Old 11-12-2002, 03:33 AM   #20
Trader Rating: 69 (100%+)
Default boiling vs baking
a bit off topic question - what do you guys do to remove tires from the rims? ive tried boiling before and they do work but it takes a while. i think i read somewhere that you can use an oven toaster to "bake" the rims until the tires come off. anyone tried this? how long should it be in the oven and at what temperature setting? how does this method compare to boiling? which is faster and has better results? thanks for any info
marvi is offline   Reply With Quote
Old 11-12-2002, 04:47 AM   #21
stormperson's Avatar
Send a message via AIM to stormperson
while not dishses, if your description of your driving skills are accurate it really wont matter.
HPI's BBS style Y-spoke rims are bulletproof. they dont warp or break, even in nitro.
the pro-line rims tend to warp i have found otherwise, they are great, but expensive
stormperson is offline   Reply With Quote
Old 11-12-2002, 09:49 AM   #22
popsracer's Avatar
Default Boiling rims/tires
Boil at a low simmer for 2-3 hours. Cool in water, then push down on the bead to break the seal. Boil more if needed.
Soaking in Acetone will dissolve the remaining CA.
This ONLY works with "Nylon" wheels. (HPI, Pro-Line, RPM, Etc.)
If you are NOT tring to save the tires. Carefully cut the tires off the rims with some body sissors. It will take less time to boil off. You may be able to reuse the inserts too.
popsracer is offline   Reply With Quote
Old 11-12-2002, 10:31 AM   #23
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Sorex
Orion
The new HPI wheels make by HotBodies..?
Tamiya = Dog Sqeeze they tend to crack with the slightest touch
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽĶ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 11-12-2002, 11:00 AM   #24
popsracer's Avatar
Default HPI dish wheels
From experience,
HPI dish wheels are 1 hit wonders. Just the slightest side hit and the center breaks out.
Old 11-12-2002, 12:15 PM   #25
Default OFNA WHEELS
The OFNA dish wheels are junk, I had the centers spit out with just one hit, but to be fair it was a little chilly, like 90 degrees!!!!
HOWEVER I have had good luck with the OFNA split 6 spoke wheels, they seem to be tons more durable.
Nylon wheels- can be straightened after warping, by nature the material used in nylon wheels have a "memory" and if you boil them they will return to the form they where first molded as.......
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 11-12-2002, 03:08 PM   #26
Herminator's Avatar
Send a message via ICQ to Herminator
What do you guys think of carbon fibre wheels?
I know they're stiff and light but I'd imagine they're brittle.
As for boiling wheels, no need to do it for so long, I've done it for 20mins and it's only still a little hard to break the super glue in the odd place, nothing a screw driver can't fix, or for a final clean up a sharp knife. Microwaving can work too but it stinks a lot more and doesn't work as well. Once dry the insirts were reusable too.
Herminator is offline   Reply With Quote
Old 11-12-2002, 04:14 PM   #27
Im2lazy's Avatar
ahem they about 9 dollars for a pair....
*AHHH*
First of all, they are too expensive, next, they are probably brittle as you point out and third... they are to expensive .
You can try 'em but I can't justify using such expensive rims when tires and inserts cost so much already.
Hpi y spokes... I've seen them warp...
Boiling, I'd rather start with new wheels. Just my opinion though.
Old 11-12-2002, 06:52 PM   #28
toolmon's Avatar
I race nitro and Yokomo Precisions are the best wheels Iíve ever tried. They are made of ABS. Do not use wheels made of polycarbonate/lexan. They break too easy. Nylon wheels bend. I used the RD Logics wheels (polycarbonate) and one of them broke off from the center going into a sharp turn after a chicane during a main. The wheel probably already had a crack from a previous crash (minor!!!), but still, a wheel should not break like that.
To remove tires off warped or cracked wheels, I use a Dremel and a cutting bit. Itís a lot of work, but itís worth the effort. RC racing isnít exactly a cheap hobby, as most of you already know, so if you have to break a sweat to save a set of tires and insertsÖgo for it.
toolmon is offline   Reply With Quote
Old 11-12-2002, 06:55 PM   #29
Im2lazy's Avatar
you mean that your wheel broke off when you did not even hit anything?
Irealize you hit something before, but it just kindof broke mid-corner?
Old 11-12-2002, 07:01 PM   #30
popsracer's Avatar
Default Reusing wheels
Really, if you think about. Log the time that you've spent saving those old wheels. Then pay yourself minimum wage for doing it.
You could have bought 2 or 3 sets of new ones at that rate.
I boiled for a few years, but it just isn't worth the effort for me anymore to do so.
WTB LARGE MT WHEELS TIRES & WHEELS 17MM + STIFF REVO SPRINGS jsm11 R/C Items: Wanted to Buy 5 07-18-2008 09:11 PM
5 sets of wheels/tires. slick, treaded, and drift. 4 dish wheels bionictony R/C Items: For Sale/Trade 2 07-12-2008 09:02 AM
IDIOTS of 2006 JVT MTX3 Chat Lounge 5 04-26-2007 12:12 AM
Losi buggy/truck wheels, tourer bodies, bling wheels I'm_Serious Australia For Sale/Trade 0 02-05-2006 06:15 PM
