Old 12-19-2005, 12:34 AM   #1
the_barbarian's Avatar
Default removing anodising
Hi just wondered if there was a chemical that could remove anodising from alloy stuff
thanks
I've tried the rest but XRAY is the best 555
the_barbarian is offline   Reply With Quote
Old 12-19-2005, 01:01 AM   #2
lol mr mussle oven cleaner works
Old 12-19-2005, 01:57 AM   #3
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
Oven cleaner wil work.. But if you want a super clean job with less chance of turning the parts black, and less health risks use this
get some drano crystals.. not regular drano.. it has to be the salt type crystals..
put the parts in Super hot water.. then put in about a tablespoon of the crystals.. it will have an alkaselzer type reaction.. it takes the color off showing the bare metal in its original color.. I have had to do alot less polishing as well since starting this method.. Ive been told anodising companies use a cheical similar to the drano..
wear gloves with either oven cleaner or drano.. both will burn your skin
burbs is offline   Reply With Quote
Old 12-19-2005, 03:43 AM   #4
thanks mate I soaked it in oven cleaner and its not purple anymore
but yea i spent like an hour polishing it wiht the dremel
Old 12-19-2005, 10:13 AM   #5
9_Ball_Slim's Avatar
Default Use Greased Lightning
Greased Lightning is the easiest and best way to take the Anno off anything aluminum.
Pour the GL in a plastic butter dish.
Put in your part.
Wait 60 min.
Pull out part and clean up with Mothers Metal Polish.
Dump the GL down the sink.
It's that easy and it's environmentaly friendly....no fumes, no fuss.
9_Ball_Slim is offline   Reply With Quote
Anodising ben73 Australian Racing 3 04-16-2007 06:00 AM
Anodising... Where to get it done. $$$... Australian Racing 5 01-26-2007 05:53 PM
bye bye anodising NVisible Electric On-Road 14 07-28-2004 10:44 PM
Anodising Parts Alvin Singapore R/C Racers 6 02-10-2004 08:37 AM
Anodising Servce?? JohnA Australian Racing 2 06-24-2003 10:27 PM
