Old 12-17-2005, 03:50 PM   #1
Superdate's Avatar
Default A question about Hara Twister 2.1
There is a diode comes with the ESC, and by mistake i soldered the positive to motor's positive said, but the negative to battery's negative side rather than the motor's. the ESC still works, but could that damage the ESC and the diode?
Superdate is offline   Reply With Quote
Old 12-17-2005, 04:27 PM   #2
fjm9898's Avatar
yes, fix it, its not doing its job right and this could either blow the diode or not protect the ESC liek its suppose to. it should go to the motors positive and negative. once you put it on right if everything still works then your good to go.
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 12-17-2005, 05:44 PM   #3
Superdate's Avatar
just want to confirm from you. if i re-solder all wires, and the ESC still works, the ESC should be alright, isnt it? otherwise i have to order a new ESC.
Old 12-17-2005, 08:11 PM   #4
BritRacer's Avatar
repost this question in the Ko VFS-1 thread. This ESC is a KO speedo.
KO staff and others will be able to help.
My guess is that the diode is toast. ESC SHould be ok.
BritRacer is offline   Reply With Quote
Old 12-18-2005, 03:50 AM   #5
a schotty diode is there to protect the ESC from spikes when u brake or something like that......
and no performance gain associated from not using one, therefore just run it even if your internal diode is busted, or just run an external one
XingXing is offline   Reply With Quote
Hara Twister 2.3 Ferrarimk13 Radio and Electronics 0 02-15-2008 05:46 PM
Hara Twister 2.2 NIB bionictony R/C Items: For Sale/Trade 1 01-29-2008 12:23 AM
Cyclone Hara edition and Hara Twister 2 speedo FUK_WRX Australia For Sale/Trade 5 10-25-2007 09:40 AM
Hara Twister/ VFS2000 Question JJ187RC Electric On-Road 1 04-03-2005 11:20 PM
Hara Twister 1 or 2 ESC tunerjetta29 R/C Items: Wanted to Buy 4 01-10-2005 11:33 AM
