Yokomo YRX12
#481
What is the shock length and droop please?
Many thanks
Many thanks
#482
I’ll check on the damper length later.
checked - 90.70 mm from end to end.
Setup the center damper so there is 0.4~0.8mm of pod droop. When set correctly the pod should be perfectly flat, not sagging down or pointing up. Just flat.
#483
Edward, who told you they were continuing to make parts?
#484
Looking for a spare/backup car, anyone have one for sale? or a NIB kit sitting around?
#486
#487
Is the mod setup sheet in the Starting Setup section on petitrc a good starting point for an YRX-12 2019 version? Also, what side springs come in the 2019 kit?
#488
#489
What tires work on CRC Black carpet and for Grey Ozite for mod?
#490
Has there been any rumors of a new YRX12 or was the 19 the end of the line?
#491
#494
Those are the same as the Associated height adapters so you use Xeon, CRC and etc.
This place has them in stock: https://www.framega.com/products/r12...-hight-adaptor
#495
