Like Tree42Likes
Yokomo YRX12
Old 03-14-2019, 11:08 AM
  #406
antlockyer's Avatar
https://www.rcmxstore.com/index.php?main_page=product_info&cPath=31_177&prod ucts_id=46979
antlockyer is offline
Old 03-14-2019, 11:16 AM
  #407
TOADYY's Avatar
They will not ship overseas
TOADYY is offline
Old 03-14-2019, 12:04 PM
  #408
antlockyer's Avatar
Email
[email protected]
Yoshihisa Okamoto
he is awesome and specialises in sending Japan only RC parts overseas. 100% solid guy who has helped me a lot.
or just wait a couple of weeks when they'll probably be at A main and Mibosport
TOADYY likes this.
Old 03-14-2019, 12:06 PM
  #409
TOADYY's Avatar
Email
[email protected]
Yoshihisa Okamoto
Thanks!
TOADYY is offline
Old 03-14-2019, 12:15 PM
  #410
slcf1's Avatar
No they won't. I've tried emailing to see if they would make an exception. No dice.
Okamoto san is great to work with.. his english is very good. I echo Antlockyer for using Beat1Racing. I've purchased many times from Beat1.
slcf1 is offline
Old 03-20-2019, 01:33 PM
  #411
slcf1's Avatar
What motors are you guys liking for 17.5? Seems like the new rotors are a bigger deal than I thought.
Yes, this is a motor question but since I own YRX's I wanted to ask my own group before the hell comes in the motor forum.
slcf1 is offline
Old 03-20-2019, 01:40 PM
  #412
TOADYY's Avatar
I have been using Team Scream V2 in my YRX12, but I will be trying the SMC Low Rider 17.5 in a week or so. I have heard a lot of good things about the SMC motors.
slcf1 likes this.
TOADYY is offline
Old 03-28-2019, 04:13 PM
  #413
TOADYY's Avatar
Default YOKOMO Diff Lock Ring for Direct drive car
Amain has the Diff Lock Ring in stock for the YRX12:
https://www.amainhobbies.com/yokomo-...-24dly/p962084
antlockyer likes this.
TOADYY is offline
Old 04-17-2019, 05:55 PM
  #414
What differences have you guys felt between the two different front ends ? Correct me if Iím wrong but with the internal shock layout less reactive caster can be use compare to the kingpin configuration.
Ricardo_d99 is online now
Old 04-18-2019, 01:30 AM
  #415
antlockyer's Avatar
when I've tried it in lowish grip it felt different but essentially the same performance. You can still get quite a bit of reactive caster with the pushrod front end by just shimming under the rear ball stud.I like the way the car feels with the pushrod front end, I like that I know my damping is consistent and that the springs are less likely to collapse.
Old 04-18-2019, 06:53 AM
  #416
do you guys run low roll centers or high roll centers for the front end ?
Old 04-18-2019, 08:35 AM
  #417
antlockyer's Avatar
Usually run with no shims under the upper arm.
Old 04-18-2019, 09:31 AM
  #418
so high roll center then, have you try running with shims under the upper arms ?
Old 04-18-2019, 02:34 PM
  #419
antlockyer's Avatar
I have but reverted back as itvwas slower. One of the guys runs a 1mm shim front and rear. Where he races tends to have a lot of initial front grip and he's trying to tame entry.
Old 04-18-2019, 03:18 PM
  #420
When you ran the shims did you change the springs accordantly? Check your pms
