Like Tree41Likes
Yokomo YRX12
Old 01-04-2019, 01:26 PM
  #391
Default Parts
Mibosport has lots of Yokomo parts. They are in Europe but shipping is quicker than one might expect and not excessively expensive either. If you canít find what you need at either T.Q. or AMain, then Mibosport is a decent option.
vafactor is offline
Old 01-20-2019, 06:34 PM
  #392
Panic09's Avatar
Default BSR purple stripe wheels
Hey guys, what kind of screws are u using to mount the rear wheels?
I noticed I can't run BSR/CRC wheels in the rear with the kit screws.
Panic09 is offline
Old 01-20-2019, 07:10 PM
  #393
TOADYY's Avatar
I have been able to use kit screws with BSR/CRC. You just need to press a little harder when screwing them into the hubs. I have also noticed a wobble in the tire when tighten too tight much or not enough.
Alternatively if you can find Serpents #411061 screw allen M3x8mm special head titanium.
Serpent Model Racing Cars - Product - Screw allen M3x8mm special head tita (10)
TOADYY is offline
Old 01-20-2019, 10:46 PM
  #394
antlockyer's Avatar
I use Xray screws when using Hotrace tyres. I suspect they will work for you.
antlockyer is offline
Old 01-28-2019, 07:41 AM
  #395
Yesterday evening I listed a really nice YRX12 in the for sale forum. It’s a complete race ready car that comes with extra chassis plates (1 graphite & 1 aluminum), spare parts, bodies, etc. A great race ready package for someone looking for a sweet Yokomo car......just in time for Snowbirds.
vafactor is offline
Old 01-29-2019, 01:34 PM
  #396
You might have a little bit bent rear wheel hub if multiple sets of tires are wobbling always on the same side when you tighten all screws tight and 1 out of 3 screws must always to be less tight to fix wobbling.
Liudas is offline
Old 01-29-2019, 02:06 PM
  #397
TOADYY's Avatar
The head of a button head/cap screw for metric is slightly larger than imperial screws which interferes when inserting a metric screw into a CRC/BSR tire. Look at the the inside of a BSR/CRC tire and you will noticed a cone around the mounting holes. That cone creates an interference fit when using metric screws and not imperial. Imperial screws drop right in. I always have to apply some pressure to get a metric screw in a BSR/CRC tire. When using Ulti Tires there is no interference fit because the head of the screw does not touch anything. So no I do not have a bent hub.
TOADYY is offline
Old 02-04-2019, 01:52 PM
  #398
brad996's Avatar
I have a couple YRX12s for sale over in the for sale section if anyone is looking for 1
brad996 is offline
Old 02-25-2019, 04:04 AM
  #399
antlockyer's Avatar
Little bit of YRX12 action from yesterday
TOADYY likes this.
Old 02-26-2019, 06:11 AM
  #400
antlockyer's Avatar
and some Stock action from Saturday
More than one person thinks my car is dying in the corners and lacking corner speed. I tried going up to a silver side spring but it just became harder to drive and no faster.
TOADYY likes this.
Old 02-27-2019, 05:50 PM
  #401
bent ō2.5mm hinge pins binding the lower wishbone movent may be the cause...
antlockyer likes this.
Smoking motor.. is offline
Old 03-09-2019, 08:00 AM
  #402
tim fry's Avatar
Two questions. What does thinner or thicker damper oil do on the front dampers?
Also now the car has been run a while there is some slight play in the front king pin should I shim this out or leave it as is?
tim fry is offline
Old 03-09-2019, 09:36 PM
  #403
antlockyer's Avatar
Hi Tim, regarding king pin play I shim it out. If it's just 0.2mm you can also wind the kingpin out a little bit to remove it.
I've never tried anything other than 1000 in the front damper.
Old 03-10-2019, 04:40 AM
  #404
tim fry's Avatar
cheers Ant
tim fry is offline
Old 03-14-2019, 11:05 AM
  #405
TOADYY's Avatar
Default YOKOMO Diff Lock Ring for Direct drive car
Where can we get this?
https://teamyokomo.com/topics/9240/
Yokomo 1/12th scale direct drive diff lock rings - Red RC - RC Car News
TOADYY is offline
