Like Tree34Likes
Yokomo YRX12
Old 09-28-2018, 03:35 PM
  #346
neallewis's Avatar
I ran mine very briefly (one 6 min run) today at MB raceway. just a shakedown run and it performed excellently. It felt quite different to the old model, but drove equally as well. I went with my same setup, 550cst (3 hole), 10k side dampers silver side springs, but with the 2019 kit silver main damper spring, not the Black I ran on the old car. It felt like it had a little less initial steering, but felt very safe to drive and push hard. I look forward to my first race with it next week.
TOADYY likes this.
neallewis is offline
Old 10-03-2018, 03:26 PM
  #347
TOADYY's Avatar
Has anyone tried the X-Ray gear diff in the YRX12? If so, how do you like it? Is the width narrower than 172mm?
TOADYY is offline
Old 10-11-2018, 06:10 PM
  #348
I may have missed it somewhere. But does anyone know of a chart for all of the optional springs? Side springs and push rod and center shock
onroad dude is offline
Old 10-11-2018, 06:17 PM
  #349
TOADYY's Avatar
YR-X12 Center Shock Springs:
Harder
  • YOKYX-40SG: Gold
  • YOKYX-40SS: Silver
  • YOKYX-40SBK: Black (kit)
  • YOKYX-40SBL: Blue
  • Softer
Front Springs:
  • YOKYX-39SG: Gold 3.5 Volume (kit)
  • YOKYX-39SS: Silver 4 Volume
  • YOKYX-39SB: Black 4.5 Volume
Roll/Tweak/Rear Side spring:
  • Harder
  • YOKR12-21SSH: Copper/Super Hard
  • YOKR12-21SH: Gold/Hard
  • YOKR12-21SM: Silver/Medium
  • YOKR12-21SS: Black/Soft
  • YOKR12-21SSS: Black/Super Soft
  • YOKR12-21SUS: Green/Ultra Soft
  • YOKR12-21SSU: Purple/Ultra Soft
  • Softer
onroad dude likes this.
TOADYY is offline
Old 10-12-2018, 07:15 AM
  #350
antlockyer's Avatar
Ran my car in Germany in 6.5 mod last weekend. ETS carpet that had a large TC race on it the week before. Grip felt quite edgy on line with practically nothing off line. Ran Hotrace Hagbergs with Speedtech sauce. Started at kit settings and tried a bunch of stuff, ended up running a blue centre spring, black sides, 10k tubes, very little rear droop, full caster and 2mm of reactive caster. Still felt like I wanted more overal grip but it wasn't like I was lacking steering other than at high speed or on power where it would just drift off line sideways rather than push through the front if that makes sense.
antlockyer is offline
Old 10-14-2018, 02:01 AM
  #351
antlockyer's Avatar
Has anyone run CRT R rear tyres before?
Old 10-23-2018, 09:10 PM
  #352
I just bought the 2019 YR x12 and was wondering if I can use a Futaba 9650 servo in the stock position. I tried reading through this thread but can't seem to find a direct mention of the servo.
Was hoping someone can give me feedback. I did see that an Xpert M3301 would work, but I would like to stay with a Futaba since I have the same on my Xray X12.
sonny8692 is offline
Old 10-23-2018, 09:34 PM
  #353
TOADYY's Avatar
I have not tried the S9650 in the direct position. Mount it and see if it would work. I have the Xpert 3301 in my YRX12 and like it.
TOADYY is offline
Old 10-23-2018, 10:48 PM
  #354
Default Xpert direct mount
Are you saying that you have the M3301 on direct? Does it also work with the stock placement?
Old 10-24-2018, 08:14 AM
  #355
TOADYY's Avatar
I am using the 3301 with the bell crank. It should work using it in direct but never tried it.
TOADYY is offline
Old 10-24-2018, 02:03 PM
  #356
slcf1's Avatar
I've tried running both configurations with the 9650.. I like the crank better for weight distribution but you can easily run it both ways.. albiet a bit cramped.
slcf1 is offline
Old 10-24-2018, 08:45 PM
  #357
Thanks for the info guys. Can't wait to finish my build and try it out.
Old 10-25-2018, 10:11 AM
  #358
antlockyer's Avatar
Ran my car at the first national race of the year and struggled. Car was inconsistent in stock and mod, although better in mod which I put down to tyre choice being more correct. Went through the car with a fine tooth comb afterwards and realised I had a LOT of front droop when set up as per the instructions. increased the gap on the pushrod from 3.5mm to 3.7mm and now have 0.5mm uptravel. Hopefully this will make the car a lot more balanced than it has been.
I'm planning to back to back the kingpin springs with the normal Yokomo layout this weekend. Should be on low/medium grip. Then again next weekend on higher grip where I also want to try the 2019 vs older car pod top plate.
Old 11-01-2018, 01:48 PM
  #359
I have tried putting the Futaba 9650 in the crank position but could not get it to fit. I am leaning on doing it direct.
Any comments?
Old 11-01-2018, 02:17 PM
  #360
tim fry's Avatar
Any comments?
You could use 1 mount and servo tape it fits fine then
tim fry is offline
