Yokomo YRX12
#286
I'm looking at picking up my first 1/12 and I am strongly leaning towards the YRX 12, what are some good parts to have that brake the most, what tuning options/hop ups should I buy for the car. Anything I should know about the car before I purchase. Also I will be running the car on mainly two tracks both polar opposite of each other. One is indoor asphalt, maybe medium grip or so, not super high and then black carpet that is super high grip, what are things I would need to do for that track? Thanks Guys
#287
RSD Yokomo YRX12 7075-T6 Aluminum Chassis and Lower Pod Plate
Titanium screws, all of the springs (front, tweak and center), upper arms and front axles.
Xpert MI3301 servo
This is what I have for my YRX12.
#288
Alum chassis for carpet:
Xpert MI3301 servo
Xpert MI3301 servo
Martin Paradis
#290
best thing to do is talk to 1/12th racers, at both tracks you will be racing at. trying to do one car for asphalt and carpet is going to be rough to the point you may need two cars. chassis switching, differences in set-up, springs front/center, shock/tube lube, tires and sizes, carpet track inline battery maybe, asphalt transverse battery, having to remove and relocate electrics, alot of work
#291
Hi I have built up the yrx-12 does anyone know what the Kit wheel base is my measurements come out a 200mm is this correct? it just to make sure the body get cuts correctly.
#292
#293
Has the design of the lower front wishbone pin being redesigned?
Part R12-12L
As one of the 2.0mm e-clips came off when it went under the carpet gap. Body too low I wasn't driving.
Not sure why they are using a 2mm e-clip on a Ø2.5 +0 -0.05MM diameter shaft this is not good engineering practice. I suspect the groove is pinching the e-clip and pushing it off the shaft. If designer used a 2.5 e-clip I suspect it would be less likely to pop the e-clip off with the correct sized groove.
I Would prefer to see them use external circlips for shafts this small as they are more secure solution to e-clips in thrust loading.
Part R12-12L
#294
Part R12-12L
Part R12-12L
AR330143 ARRMA Heavy-Duty Hinge Pin Set 2.5x36mm
https://www.ebay.com/itm/NEW-ARRMA-H...53.m1438.l2649
#295
these guys make alot of YRX12 stuff to the point that the car becomes almost a 12R5 or X12
Red RC ? RC Car News » Team Bomber YRX-12 chassis conversion kit
#296
I love Team Bomber. Just be aware that the chassis wheelbase is 2mm longer than stock. You can run kit frontend on their chassis. To use AE/Xenon frontend, you need to purchase the adapter front bulkheads.
#297
so few of the Japanese sites are internet shopping friendly for outside countries and hard to know what i'm really doing. even using a translator only portions translate, i'm not sure what is going on after several pages or even know what would happen on a order from US. Team bomber, Kawada, kimihiko-yano, etc. but sure they go thru the same thing if they hit some US sites for stuff
i found a few team bomber bodies to try on stormer hobbies sold under schumacher brand
team CRC Japan CK25 is longer also than US version
#298
Kimihiko Yano us a great guy to deal with. Email him what you want, he works out shipping, you pay and it arrives not long after. Beat1 Racing also are veey good at getting Japanese goods sent out to us foreigners.
#299
I order direct from TeamBomber on FB. Just use the translator and everything is fine.
#300
Does everyone use thread lock on the screws I had the axel come of due the m2.5 x 4 long screw coming lose.
