Old 12-16-2005, 08:38 PM   #1
tornado
Guest
Posts: n/a
Default SPEKTRUM HELP !!
Hi !!
hope someone here could help me. My spektrum lately having a mind of its own. Playing pan car 4 cells. Out of the blues my car will make a right turn and it always have to happen when I'm running a full speed down the straight !!. I'm also using a seperate receiver pack. Any ideas ??
After the crash, the whole electronics fail to respond. I need to switch off and on again to regain control.
Old 12-16-2005, 08:47 PM   #2
Jeff Brown's Avatar
Well...... not sure which system you have. There was problems with Futaba and such. I have heard a bit about "glitching" with them as well. I would contact Horizon regarding it for support.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 12-16-2005, 10:36 PM   #3
Twin-Kyle's Avatar
What speed control are you using??
Twin-Kyle is offline   Reply With Quote
Old 12-16-2005, 10:37 PM   #4
rocketron's Avatar
Trader Rating: 16 (100%+)
I've seen this happen with receiver packs and without and each time this was solved by using a capacitor plugged into a spare slot in the tranceiver. when the spektrum system senses low power it will do what some call a "glitch". Spektrum has a capacitor or you can put a plug on a 4700mf esc capacitor and try it. Are the receiver packs batteries strong?
Good Luck and I too would reccomend you contact horizon or maybe go to the spektrum website for more detail.
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 12-17-2005, 02:40 AM   #5
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
depending on how old your spektrum is they are replacing some of the older units.. even if you just bought it the shop could have old stock.. they had some problems with recievers, and some with the modules.. it isnt futaba specific its the sytem.. i race 4 cell oval.. the reason it sudenly turns is it goes into a safe mode because it loses signal.. My buddy had Sonny Brown from horizon swap out his sytem.. I would call horizon and ask for him.. He has been doing alot of testing t find out the actual causes of this..
burbs is offline   Reply With Quote
Old 12-17-2005, 10:36 AM   #6
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
The older models had a faulty positioning of the antenna wire. They would sometimes come loose causing a bad connection, obviously. This has been straightened out with the newer Spektrum.
Team Duratrax is offline   Reply With Quote
Old 12-17-2005, 10:46 PM   #7
Drewdc90's Avatar
Can any tell me if the Spektrum controller has expo on the steering and or throttle similar to my JR XS3?? I want to update but don't want to go backwards with the controller. Otherwise I'll have to buy a 3PK and the module/ receiver. Any suggestions which way to go ??
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 12-18-2005, 12:09 PM   #8
i had this problem.
first time i used it in my 1/10th car mod it glitched to the right and wouldnt go back to neutral after turning.car seemed to fast of responce and was very twitchy on steering.this was indoor carpet and high traction and now i have reverted to the normal radio system.
i yet have to test it outdoors and will wait till the wether bucks up.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 12-18-2005, 01:58 PM   #9
DerekB's Avatar
The Spektrum TX has EXPO.
Velocity RC Magazine
www.vrcmag.com
DerekB is offline   Reply With Quote
Old 12-18-2005, 02:14 PM   #10
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
I believe that radio is the older non synthesized version of the radio you have, other than that the features are the same. So it wouldn't be a step down feature-wise.
Rod
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 12-18-2005, 02:25 PM   #11
ChadCapece's Avatar
Upgrade to the 3pK or M8 or Helios!
The XS3 is well above the DX3 (spektrum controller). I've used both and the XS3 is much better. So don't get the DX3 if you're wanting to upgrade.
ChadCapece is offline   Reply With Quote
Old 12-18-2005, 06:18 PM   #12
DerekB's Avatar
I'm not sure why we want all these functions we don't use. I use EPA and sometimes ARC to smooth out the throttle, and Subtrim and that's about it. You can get the DSX with those features far cheaper than the other radio's plus DSM.
I don't really care for the ergonomics of the DSX though. Always grab and feel before you buy.
www.vrcmag.com
Old 12-18-2005, 06:29 PM   #13
ChadCapece's Avatar
The M8 is much easier to make changes, and visual what changes you've made. Also, more precise expo changes. Servo speed can be adjusted. On the fly dual rate adjustments. More model memory. Smaller recievers. Less glitching.
Old 12-18-2005, 07:49 PM   #14
jamescam's Avatar
R/C Tech Charter Subscriber
Is true in RC racing and at the Bunny Ranch.
jamescam is offline   Reply With Quote
Futaba 3PKS - Lipo Tx Pack - Spektrum Module - Spektrum Micro Pro Reciever - Case racer34v R/C Items: For Sale/Trade 2 06-20-2008 09:42 AM
HUGE SALE TONS TC5, Novak Speak Spektrum GTB 13.5, Spektrum Pro, AMB Transponder + mach51 R/C Items: For Sale/Trade 16 01-08-2008 03:11 PM
Electronics For Sale: M11/Spektrum, Spektrum Micro RX, Futaba Synth etc. johnnyboy R/C Items: For Sale/Trade 3 11-30-2007 08:17 AM
swap ko propo helios radio with spektrum pro for 3pk super with spektrum pro willabong Australia Wanted to Buy 0 04-01-2007 05:39 AM
Spektrum receiver...Spektrum 590 Servo...PCR Temp gun...CRT Roto start... SCUBA STEVE R/C Items: For Sale/Trade 8 08-22-2006 09:18 AM
