Team Associated F1
#1112
I have not done a ton of research, but is this car done? If so how much longer will parts be available?
#1113
AE is getting out of the onroad game and the RC10F6 is being discontinued (if not already).
#1114
Can somebody list the parts and part no. needed to build the conversion to front mounted servo?
I want to make sure I don‘t miss something important.
#1117
well, yes, the manual shows the steps for building.
But to me it was not obvious, which parts are needed and what parts can be used from the kit.
So that’s what I count:
1x 8656 Forward Servo Mount
1x 8654 Front Top Plate Standoff
1x 8652 Suspension Arm Standoff, Upper (4pcs, + 4 setscrews)
1x 8636 Front Top Plate
Did I miss anything?
I expect I can use the screws and bushings included in the kit.
#1119
Thank you! Yes, I‘ll do that!
#1121
Unfortunately, I think I’m reaching the end with my F6. I’m tried of the same problems. The upper arm bushings.
Outdoor pavement starts next weekend. Carpet practice yesterday. Will see how it goes. Before making a decision on looking for another F1.
#1123
https://youtu.be/5JP20elkTN4
If you swap out the carbon stock upper arms with the Exotek adjustable front end that will eliminate all of your bushing issues. Also makes it much easier to change caster and camber, no more need to have to take the front end apart.
#1124
Yup. Everybody been reminding me of that system. Seems to be out of stock everywhere. I had forgotten about it. I’ve run my F6 more this year then in previous 15 months.
