Team Associated F1 >
Team Associated F1
Like Tree331Likes
Team Associated F1
Old 03-26-2019, 10:48 PM
  #1081
Originally Posted by 0010
How are you getting a spool for this car? Are you putting the pins in the diff or is there an actual spool you can get for the car? Is anyone using the X-ray gear diff with success?
thanks!
I have been running the X-ray diff on crc carpet and have had good success with it. I run 100k in it, and it is a great middle step between balls and a spool. The car will rotate, but doesn't want to step out on power as bad.
Megatron328 is offline
Old 03-31-2019, 10:22 PM
  #1082
Outdoor season startes yesterday and I went for my F6. It ran nicely on carpet and I wanted some challenge on asphalt I decided to go with my F6.
Drove new Ride ETS wheels (so there shouldn't be an issue with the tires) and our local fast guy drove my car really didn't like the car. Steering seems okay but the rear is nothing near planted. Acceleration out of corners is bad, because the rear is very loose.
I tried to adapt to a medium grip little bumpy track:
- 10k in tubes
- blue side springs (have the Tamiya Set on hand)
- diff as light as possible
- black shock spring (oil should be 40wt?)
Softening up the rear helped but still not easy and nice to drive.
One big issue I have is ride height:
Rear gets the +1 inseei and I end up at 5ish mm height. But front? How to I manage the front?
Have no shims in the front except above the inline steering blocks (like the manual does). I had 2mm and needed to go up to 4mm shimming to get at least a little more than 4mm ride height. But that kills all the droop? It's just 1mm or so?
What I don't understand: how can the setup sheets on petitrc rc have 4,6mm ride height with just 1mm shimming above the steering block? Do they have shorter standoffs?
Or any other idea to get more rear grip? Don't know the current front end settings but it should be a mix of different petitrc setups.
man1ac is offline
Old 04-01-2019, 06:19 AM
  #1083
Billy Kelly's Avatar
3rd try with carpet. Improvement
Billy Kelly is offline
Old 04-01-2019, 01:09 PM
  #1084
liljohn1064's Avatar
Trader Rating: 17 (100%+)
https://youtu.be/QrFJVVppoFA
Looks pretty decent. Nice line. I'd have liked to run my F6 back to back with my TRF103, but it was TCS so I left it at home. I was running roughly 12.9 to 13.2 for consistency. I still have to put slipper pegs in my Tamiya diff and put the gear diff in the Associated and give those setups a try on black carpet.
liljohn1064 is offline
Old 04-08-2019, 06:55 AM
  #1085
Gearing change. Started off, was getting a lot of traction roll unlike previous week. But slowly improved as day went. So far I’ve cut a second off each week.
Old 04-11-2019, 09:57 AM
  #1086
Dumb question, but how do you adjust rear pod droop? I have looked at the manual and searched threads, and I am not sure. I know shock length plays a part, but do you have to rebuild and add shims in the shock body if you want less droop? Or is it by adding washers under the rear shock mount to raise the height of the ball? If that is not a droop adjustment, what does adding/removing washers on the shock mounts do?
Thanks in advance!
0010 is offline
Old 04-11-2019, 12:42 PM
  #1087
Thanks in advance!
Unscrew the shaft from the ball socket, then adjust preload on the center spring to get it back to level. Just try a couple threads at a time until you get what you like.
Old 04-22-2019, 10:01 AM
  #1088
Anyone having issues blowing up the left side flanged bearing on the rear axle when using the Associated rear axle spacers? I had only had one bearing failure after a number of hard hits to the left side prior to adding 2mm spacers to each side, then I had two fail in one day after. I think the spacers puts all of the load on the inner race, so if you make contact, that is the only place for give.
Has anyone else experienced this? What is everyone else using for axle spacers front and rear?
Thanks!
0010 is offline
Old 04-22-2019, 02:19 PM
  #1089
Trader Rating: 34 (100%+)
Thanks!
Unfortunately, that is the way the axle is to be assembled on the bearing. Any hard hits like you experienced are going to take out that bearing. You can look for a thrust bearing that will mount to the outside of the bearing carrier and then shim your axle width from there, but I don't have information to share with you about the part number for that thrust bearing. I know it would be around 5mm inside diameter, but it would need a large enough outside diameter to catch the bearing carrier instead of going into the axle bearing. Just going to have to stay off that hard wall.
davidl is offline
Old 04-22-2019, 10:24 PM
  #1090
Thanks David! Staying off that wall is easier said then done!
0010 is offline
Old 04-24-2019, 07:01 AM
  #1091
Can somebody pls tell me the lenghts of the standoffs used in this car? Maybe need them for another project.
Thanks in advance Gero
Gero is offline
Old 04-24-2019, 07:19 AM
  #1092
Are you looking for the lower arm standoffs, upper front plate standoffs or both?
0010 is offline
Old 04-24-2019, 11:50 AM
  #1093
Looking for both. Around 14mm would be perfect.
Gero is offline
Old 04-24-2019, 01:58 PM
  #1094
MikeR's Avatar
Trader Rating: 15 (100%+)
Thanks!
Instead of using a spacer just use another flanged bearings and face the flanges against each other on the axle -II- (if this makes sense).
This will spread the side impact across 2 bearings instead of 1.
Tim Neja and Fredp1 like this.
MikeR is offline
Old 04-28-2019, 06:01 PM
  #1095
Default Rear Axle bearing
Glad to see you ran last Friday nights main with out any problems. I was able to see why you couldn't stay off the wall and understand your dismay at the result. But now you should be good to go and avoid further issues with that axle bearing.
davidl is offline
