Team Associated F1 >
Team Associated F1
Like Tree331Likes
Team Associated F1
Old 02-05-2019, 02:31 AM
  #1006
Not much action here. sadly. Currently setting up a used roller so bought. F1 is so different than buggies or TCs.
I hate the battery tape topic and want to switch to the Exotek 1824 system. Is it any good? It comes with some springs I don't need (running only on black ets carpet).
Are there any gearing information? Will be running 21.5T on a small carpet track...
man1ac is offline
Old 02-05-2019, 03:16 AM
  #1007
Billy Kelly's Avatar
Things slow down during winter. Not everyone has an indoor location to run at. Typically I get an unwanted 30 weeks of inactivity with mine. I will be finally getting to try carpet soon. Though Iím unsure about racing carpet yet.
I just used velco to hold the battery. Two summers of outdoor with no issues.
Billy Kelly is offline
Old 02-05-2019, 03:45 AM
  #1008
Okay, thanks. I don't have a summer Track so carpet all year it is
How do you remove the battery? Really with lifting the shock every time? Seems way too complicated, but I don't think I overlooked something.
man1ac is offline
Old 02-05-2019, 03:54 AM
  #1009
Mr. Bubby's Avatar
I've got the Exotek rear end for the car and I just love the battery stay. You don't have to clip off the shock, just unscrew one of the screws all the way out and the other side just slides in. I don't even use tape. Yes, the battery moves around a bit, but just put a piece of double sided tape on the underside of the battery and it should stay put.
man1ac likes this.
Mr. Bubby is offline
Old 02-05-2019, 04:01 AM
  #1010
Just unscrew one side of the shock , and change battery. Now Serpent has a new F1 with a bottom door for changing battery
Old 02-05-2019, 04:10 AM
  #1011
Okay, yeah it's quite fast, but I am completely new to F1s and they are so different than any other car I have.
can't wait to get it going on Friday.
Any setup tips? Was looking at PetitRC and would pick some for black carpet...
man1ac is offline
Old 02-05-2019, 04:23 AM
  #1012
I’m still relatively new to F1, 20 racedays over 2 summers. I built mine strictly off the book. Haven’t changed any settings yet. It’s been a long learning curve for me. Started off with a slow car till I was more comfortable with it. With carpet still a foreign surface to me, I found on pavement easy to spin when braking and off the start line. I’ve slowly progressed and made a change before winter, replaced the esc. The Reedy blackbox had a dead spot for me. Switched to a Hobbywing wing and my one, quick test showed big improvement.
The common weak spots for me have been front wing and the side pod links. First year went through 3 wings and around 8 sets of links. Second year out parking lot was resurfaced and had no breaks. Our lane barriers have a lot of give to them compared to what I’ve seen in video for carpet tracks.
Have fun with it. It’s a definite challenge compared to TC. By the number I see try and not stay witu F1, it’s clear that for some it can get fustrating.
Old 02-05-2019, 05:40 AM
  #1013
Is there a stronger side links part? Someone mentioned Xray? Just have 1 Set of spares.
Maybe I could 3D print them myself?! Dunno how strong they would be (or accurate?!)
man1ac is offline
Old 02-05-2019, 05:44 AM
  #1014
The XRAY ones should fit. After my last break an XRAY owner measured a set to be the same. I bought a set but haven’t installed them yet. Since didn’t break anything last summer. I should install them this year.
Old 02-05-2019, 06:06 AM
  #1015
Do you have a part number?
man1ac is offline
Old 02-05-2019, 06:33 AM
  #1016
man1ac likes this.
Old 02-05-2019, 07:29 PM
  #1017
mtveten's Avatar
Trader Rating: 29 (100%+)
Tamiya F104 links are also the same size and come in both soft plastic and carbon reinforced versions.
aracefan likes this.
mtveten is offline
Old 02-05-2019, 11:06 PM
  #1018
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Xray links > Tamiya
Dan is offline
Old 02-09-2019, 07:11 AM
  #1019
I recently got the PSM side braces/battery hold down for mine and I love them. The o ring is super convenient, and the battery position adjustment is extremely useful.
Megatron328 is offline
Old 02-09-2019, 10:05 AM
  #1020
Ist there a chance to convert the F6 to R6?
man1ac is offline
