Team Associated F1 >
Team Associated F1
Like Tree331Likes
Team Associated F1
Old 11-25-2018, 03:35 AM
  #991
gigaplex's Avatar
I've been battling with my car on and off for some time now, and it's never felt quite right. At low to mid speed it feels pretty good, but once I get half way down the straight it all goes pear shaped. I decided to take some drastic measures today when I remembered that the AE front wing has a reputation for being too aggressive, so I removed it entirely. The car was finally stable on the straight and I could actually use full throttle for the first time. It pushes a fair bit in the sweeper now, as you'd expect, but I was still about a second a lap quicker without the front wing. Typical laps on this track are in the 18+ second range, outdoor asphalt. What are some low downforce front wing options for the F6? Or maybe some higher downforce rear wings?
gigaplex is online now
Old 11-25-2018, 04:50 PM
  #992
sonic31's Avatar
Trader Rating: 6 (88%+)
mon-tech makes good wings
sonic31 is offline
Old 11-25-2018, 05:05 PM
  #993
fat500's Avatar
Trader Rating: 51 (100%+)
let me help you a little more then telling you company a makes good stuff
The montec wing has two different inserts that work very well. one med. and one high downforce. if you use neither you get a minimal effect and this can really calm the car down.
The tamiya f60 wing is high nose but you can adjust the two small front winglets to adjust downforce by removing one screw,
I am currently running the montec with the med insert with good results.
It is amazing how much the front wing plays a role on these cars., Do not go too big on the rear may slow you down....try raising the wing up on the rear mount and play with angle too. good luck
fat500 is online now
Old 11-25-2018, 06:12 PM
  #994
1/4milecrazy's Avatar
I wish everyone would answer questions like this. Sarcasm but with a very detailed answer that actually answers the question and is helpful.
Vintagedriver likes this.
1/4milecrazy is offline
Old 11-26-2018, 04:31 AM
  #995
Trader Rating: 19 (100%+)
The sarcasm was aimed at Sonic. He had it coming a little. LOL. We're all good friends and enjoy racing and a little competitive banter between us.
astgerma52sp is offline
Old 11-26-2018, 09:58 AM
  #996
sonic31's Avatar
With a name like fat500 you wonder which is it? 500lb or just fat ... here's some details: the mon tech wings like others on the market offer adjustability, fat500 has no adjustments, less or more downforce but in my opinion mon tech feels stiffer and stronger, not like fat500 who's soft and peachy, it should handle impacts better, much better than protoform.
Tamiya wings are also nice but fat500 runs Tamiya so beware.
PS, i love u fatty5000
sonic31 is offline
Old 11-26-2018, 03:23 PM
  #997
the mon-tech v2 is good but you can chip each side of the wing easy if you hit the wall or cut a corner too quick.... for me i prefer the mon-tech V1 because they feel stronger and stiffer and handle impact better than the V2
Quinny45 is offline
Old 11-26-2018, 04:25 PM
  #998
Trader Rating: 38 (100%+)
I have always had the best luck with a Tamiya J wing 51383. Been racing the same wing for 4 years without breaking it. And I hit things pretty hard when I do, lol.
Rick Vessell and astgerma52sp like this.
chensleyrc1 is offline
Old 01-10-2019, 09:36 PM
  #999
Default Mods required
Seriously considering this car. Replacing my TRF101, was thinking the F6, Roche or Serpent.
What are this cars pros and cons from people who have run it for a full season?
I hear the front suspension standoffs are weak and the Exotek brace is a good fix. What else?
Also, is there a steel axle option? I have carbon shafts, really needs a steel shaft.
dman18t is offline
Old 01-11-2019, 08:52 AM
  #1000
sonic31's Avatar
Get the stronger standoffs, look at exotek they have a couple good upgrades, upgrade the pivot bslls on the upper arms to the metal ones, upgrade the caster and camber pieces to aluminum
sonic31 is offline
Old 01-11-2019, 09:07 AM
  #1001
RobS's Avatar
I've been running this car for a year or so now and have given it a good beating. I have heard of the front standoffs bending but I've personally never ran into that problem. The only issue I did have was the side links breaking easily. I actually replaced them with some Traxxas links and never had a problem since. Aluminum camber/castor inserts wouldn't hurt though.
RobS is offline
Old 01-12-2019, 05:06 PM
  #1002
Traxxas links for what?
dman18t is offline
Old 01-12-2019, 07:04 PM
  #1003
RobS's Avatar
To replace the rear pod link (ASC4728).
RobS is offline
Old 01-12-2019, 08:53 PM
  #1004
Billy Kelly's Avatar
Was wondering same thing.
What traxxas part part did you use? XRAY links also fit.
Billy Kelly is offline
Old 01-12-2019, 10:20 PM
  #1005
Obviously, I mean what Traxxas part # or Traxxas car uses Links?
Billy Kelly and gigaplex like this.
dman18t is offline
