Team Associated F1 >
Team Associated F1
Like Tree331Likes
Team Associated F1
Old 10-12-2018, 02:26 PM
  #961
jpx
jpx's Avatar
Originally Posted by sonic31
that stand off i used is from an Emax nighthawk drone, on ebay they sell a hardware set for that which includes those standoffs.
i used a 8 or 10mm long set screw on the servo mount part with a 1mm wide spacer + a 2mm alum. spacer.
everything else is kit std.
What is the benefit of the long damper setup?
And is the servo mount fixed to the main chassis in the rear or floating?
jpx is offline
Old 10-12-2018, 02:27 PM
  #962
J Lee's Avatar
that stand off i used is from an Emax nighthawk drone, on ebay they sell a hardware set for that which includes those standoffs.i used a 8 or 10mm long set screw on the servo mount part with a 1mm wide spacer + a 2mm alum. spacer.
What about that long black tube?
J Lee is offline
Old 10-12-2018, 05:17 PM
  #963
sonic31's Avatar
Trader Rating: 6 (88%+)
emax nighthawk drone frame standoff with black heat shrink tubing over it to hide the colour.
Tandum4056 likes this.
sonic31 is offline
Old 10-12-2018, 05:18 PM
  #964
The benefit of the long shock is usually better rear traction, it's helpful on asphalt and really low grip carpet.
Megatron328 is offline
Old 10-13-2018, 06:10 AM
  #965
jpx
jpx's Avatar
So the better rear traction using the long shock setup is acchieved by more chassis flex?
And will the rear servo mount be fixed to the main chassis or not when using the long shock configuration?
jpx is offline
Old 10-13-2018, 07:18 AM
  #966
Among some other things I'm a little fuzzy on, yes. And you could try either way, mounted to the chassis or floating, it just depends on what you like and what surface you're racing on. It's still a flex adjustment.
jpx likes this.
Old 10-15-2018, 03:12 AM
  #967
Joost K.'s Avatar
I have a question for the users of the car.
What is the outer diameter of the lower suspension arm pivot ball???
Either in inch or metric but I need the precise measurement.
Thanx in advance!!
Joost K. is offline
Old 10-22-2018, 02:12 PM
  #968
new to f1 my car pulls to the left hard on power. runing on black carpet.
SGrubb is offline
Old 10-22-2018, 03:05 PM
  #969
aracefan's Avatar
Trader Rating: 69 (100%+)
If it is going "straight" while going slow, like checking to make sure it goes straight, and only goes left under full throttle situations, check;
  1. Tweak in the car.
  2. Bearings
  3. Weight distribution - this shouldn't matter too much under hard acceleration unless it's a lot...
  4. Check your front kingpin springs, make sure they aren't very old - those little springs give up after some runs (especially after kissing the barriers).
Put the car on a setup station if you can, not imperative but it helps. If you have good calipers you can measure steering left to right to check it. Also, if you can't find it in the 3 listed, throw on a different set of tires and see if that makes a difference, because if you are running CRC premount tires the fronts can sometimes be horribly out of balance...
aracefan is offline
Old 10-22-2018, 03:44 PM
  #970
So basically all i did was drill out the holes on the suspension arms, again i used a 19/64 drill bit.
the red circled areas are where i used the drill bit, hope that this is helpful, thanks.
Could anyone supply a part number/name for the circled parts, such that they could be bought seperately? Looking for the ball and cup that inserts into the carbon suspension arm. Thanks!
ptrhahn is offline
Old 10-22-2018, 03:48 PM
  #971
aracefan's Avatar
Suspension Arm pivot ball bushing; Part# 4754
Suspension Arm pivot ball; Part# 4755
sonic31 and ptrhahn like this.
aracefan is offline
Old 10-22-2018, 04:16 PM
  #972
Billy Kelly's Avatar
After 2 summers decided to make a esc change.
aracefan likes this.
Billy Kelly is online now
Old 10-22-2018, 06:16 PM
  #973
gigaplex's Avatar
aracefan already directly answered your question, but the part numbers are quite clearly labeled in the manual.
gigaplex is online now
Old 10-22-2018, 08:16 PM
  #974
sonic31's Avatar
the part numbers for those circled parts are in the manual
sonic31 is offline
Old 10-23-2018, 03:37 PM
  #975
  2. Bearings
thank you for your help. i found the two screw came out of the back of the car. i will put the tires on the balancer
SGrubb is offline
