Team Associated F1
#931
Hello everyone, im new to the F6 chassis and like everybody else i had a very tight front suspension. I was told to sand down this or that to free up the pivot balls but instead i used a 19/64 inch drill bit and drilled the holes in the upper arms. Now its perfect, its not super tight like before but also not loose where it falls out and no more tight suspension! If you're gonna try it remember to use a (19/64 inch drill bit). That size has worked perfectly for me.
#940
Unfortunately my summer racing has been cut short. Weather caused Labor Day weekend to be canceled. And family schedule for the majority of group had caused the cancellation of yesterday’s racing. Overall I made big improvement, no broken parts and consistency made big jump. I’m still well off the pace. Hopefully I won’t have a repeat of that winter, going 30+ weeks without running. Here’s video from what has become last race of summer.
#941
After watching the video, I can tell that your car is planted enough for you to push it to the racing edge and get back on pace...You can't be hesitant or worry about crashing too much if you want to go really fast....
#943
I understand now..... I had the same brake issue with my 25.5t novak motor: I had no brakes and could not push it at all....I switched to a 25.5t fantom v2(1590 rotor) and recovered all the necessary braking to be able to push it... Esc settings did not seem to do anything for brake strength: only lower fdr(went from 2.8fdr to 3.28fdr) , rotor strength and motor inductance seem to improve braking...
#945
Hopefully i wont have long layoff driving the F1 this winter.
