Team Associated F1 >
Team Associated F1
Like Tree331Likes
Team Associated F1
Old 04-18-2018, 08:42 AM
  #856
Trader Rating: 14 (100%+)
Originally Posted by Serzoni
I believe they're 10.75mm
Thanks Serzoni!!
TimXLB is offline
Old 04-18-2018, 07:14 PM
  #857
Originally Posted by Tim Neja
I'd check the screw holding the aluminum upright. It's probably bent--not the upright. FWIW
It was the upright.
Tim Neja and gigaplex like this.
DoubleRR24 is offline
Old 04-19-2018, 07:13 AM
  #858
That's.. not gonna buff out.
Serzoni is offline
Old 04-19-2018, 09:49 AM
  #859
Tim Neja's Avatar
Originally Posted by DoubleRR24
It was the upright.
WOW---that must have been quite a HIT!!! Good that you found the problem--makes an easy FIX!!
LonnyJ1950 likes this.
Last edited by Tim Neja; 04-19-2018 at 09:50 AM. Reason: But of course now it's "adjustable--just spin it the direction you want to angle the arm!! :) :)
Tim Neja is offline
Old 04-19-2018, 10:33 AM
  #860
I can't remember when it was, but this is my first time driving an F1/pan car, so I was all over the place. I'm glad that I picked up the new, stronger uprights when they came out, so I didn't have much down time.
Old 05-06-2018, 11:44 AM
  #861
Billy Kelly's Avatar
Time to start running again after long winter break
Billy Kelly is offline
Old 05-10-2018, 10:06 AM
  #862
jpx
jpx's Avatar
I know it was allready discussed but couldn‘t find the right posts anymore ...
Which steel pivot balls can be used instead of the plasic ones for the front suspension arms?
I had some at home with a diameter of 5.8 mm but this is too small - the arms will have some slope especially vertically.
So I guess I need some with a diameter of 5.9 mm.
Which ones can I use?
Do the B5 shock pivots work?
Associated B5 #91448
Or any other links / part numbers?
jpx is offline
Old 05-10-2018, 10:23 AM
  #863
shadowracer24's Avatar
I used the B6 pivots in mine. Just had to lightly use my reamer on both sides of the sockets until the pivots moved smoothly. Vastly improved the way the car works now.
shadowracer24 is offline
Old 05-11-2018, 05:46 AM
  #864
jpx
jpx's Avatar
Would you have the part# for me, please?
jpx is offline
Old 05-11-2018, 08:56 AM
  #865
Tim Neja's Avatar
Hmmm--I've built two of these cars for friends and I didn't have any slop in these? Have they changed the kits recently? Both cars I built are working very well. Mike Mayberry has one--but we DID experience a weird thing--he stripped TWO spur gears back to back. We could not find any movement in the motor? Has anyone experienced this before?? I ensured the gears were properly set for mesh both times---I've got 3 other F-1's and have not had any problems on any of them???
Tim Neja is offline
Old 05-11-2018, 09:24 AM
  #866
NutDriver's Avatar
Trader Rating: 30 (100%+)
Default Rear axle ride height inserts
A friend had an issue with stripping spurs. He finally diagnosed the issue of having one of the rear axle ride height adjusters in the forward position and the other in the rear position.
Tim Neja likes this.
NutDriver is offline
Old 05-11-2018, 10:46 AM
  #867
InZane's Avatar
Default Stripped spur
I noticed a small play between the pod and the height adjusters - fixed it with aluminum tape.
jpx and aracefan like this.
InZane is offline
Old 05-11-2018, 02:07 PM
  #868
HYPERformance06's Avatar
what tires would u guys recommend for small asphalt covered in sugar water?
HYPERformance06 is offline
Old 05-11-2018, 02:18 PM
  #869
aracefan's Avatar
Trader Rating: 70 (100%+)
Ride GR, and for a hot track (high temps -summer temps) Ride GR-X. Don't know how the Yok's or Hudy's do on asphalt.
aracefan is offline
Old 05-11-2018, 02:25 PM
  #870
any recommendation on where to order? our cars use the f104 style rims correct?
