Team Associated F1 >
Team Associated F1
Like Tree331Likes
Team Associated F1
Old 04-03-2018, 05:16 AM
  #841
As I was doing routine maintenance on my chassis, I noticed that the right suspension arm seems to be angled up more that the left, as you can see in the picture.
Any thoughts/ideas on what could be causing this? I've double-checked the build and everything seems to be exactly as the manual calls for it to be.
DoubleRR24 is offline
Old 04-03-2018, 06:09 AM
  #842
It looks like you've bent the standoffs on the right side of the car. Replace them with the HD Associated standoffs or the Avid standoffs.
https://www.teamassociated.com/parts..._arm_standoff/
Serzoni is offline
Old 04-03-2018, 06:51 AM
  #843
Thanks. I didn't even notice that.
Glad I already picked those up.
Old 04-06-2018, 09:50 PM
  #844
Flagler's Avatar
Has anyone had trouble fitting certain shorty packs in the chassis? What batteries are you guys using that fit?
Flagler is offline
Old 04-07-2018, 04:50 PM
  #845
I'm using the Gens Ace 4600 mAh shorty pack and I haven't had any issues with the fit.
Old 04-16-2018, 09:27 AM
  #846
J Lee's Avatar
Hello, guys what other manufactures Front wing directly fit on the F6?
J Lee is offline
Old 04-16-2018, 09:30 AM
  #847
J Lee's Avatar
Also a question, what's the purpose of front droop screws being washers and plastic head and all that fancy things? anyone else just has 3x8 button head screws on it?
J Lee is offline
Old 04-16-2018, 10:38 AM
  #848
Without longer M4 screws, none. With longer screws, any front wing should fit, aside from special wings like WRC.
My guess would be that the plastic won't mar up the bottom of the upper arm like a steel screw would.
Serzoni is offline
Old 04-16-2018, 01:05 PM
  #849
J Lee's Avatar
Thanks. also, does anyone tried running the car with a rigid axle by removing the diff balls but no diff pegs either? I have been running without nor Diffballs or pegs, was wondering if there is any performance gain by running those Traxxas pegs. or a better question can be, does anyone makes a rigid axle for the chassis?
J Lee is offline
Old 04-16-2018, 05:58 PM
  #850
Tim Neja's Avatar
Most F1 cars take a shorty "thin" or "low profile" battery to properly fit the cars! Fantom racing has both---their out of stock on the low profile but they have the "thin" version that will work fine.
Tim Neja is offline
Old 04-16-2018, 06:01 PM
  #851
Tim Neja's Avatar
I'd check the screw holding the aluminum upright. It's probably bent--not the upright. FWIW
Tim Neja is offline
Old 04-17-2018, 07:36 AM
  #852
Trader Rating: 39 (100%+)
Almost all F1 wings will fit on the front. Mon-tech, Tamiya, Xray, Protoform. I can't comment on something like WRC or TRG though. One caveat to all wings aside from the kit wing is that you will need a longer screw. The AE wing has a cutout for the body post mount while all other MFG's do not.
Jamie Hanson is offline
Old 04-17-2018, 12:24 PM
  #853
J Lee's Avatar
Thanks. I m gonna try to get Xray wing. since the AE wing is out for a long time.
J Lee is offline
Old 04-18-2018, 07:49 AM
  #854
Trader Rating: 14 (100%+)
Hi, I am looking for the overall length of part #8665. trying out something and they look like they might work. Thanks in advance!!!
TimXLB is offline
Old 04-18-2018, 08:09 AM
  #855
I believe they're 10.75mm
Serzoni is offline
